THIS IS WHAT I GET
####40#W####��##(###��# ��#####i############��#�����#��#�E
Texas Instruments X-Loader 1.4.4ss (Jan 29 2011 - 10:54:03)
Beagle Rev C4
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03 (Feb 14 2011 - 21:26:52)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max clock-720Mhz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C error.
timed out in wait_for_pin: I2C_STAT=0
I2C read: I/O error
Unrecognized expansion board: 0
Beagle Rev C4
Die ID #54f6000400000000040373050f019004
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatload mmc 0 0x80300000 uImage
reading uImage
3195988 bytes read
OMAP3 beagleboard.org # setenv bootargs console=ttyS2,1152000# #n*# #8
noinitrd root=/dev/mmcblk0p1 rootfstype=ext2 rw rootwait nohz=off
OMAP3 beagleboard.org # bootm 0x80300000
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3195924 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.................................................................................................................................................................................................................
done, booting the kernel.
[ 0.000000] Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3
(GCC) ) #3 PREEMPT Mon Jan 24 17:19:47 CET 2011
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 noinitrd
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 238336KB available (5900K code, 671K data, 204K
init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 510.47 BogoMIPS (lpj=1994752)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 265.884735] OMAP DMA hardware revision 4.0
[ 265.893829] bio: create slab <bio-0> at 0
[ 265.895477] SCSI subsystem initialized
[ 265.897247] usbcore: registered new interface driver usbfs
[ 265.897430] usbcore: registered new interface driver hub
[ 265.897674] usbcore: registered new device driver usb
[ 265.898101] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 265.901306] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 265.901367] twl4030: power (irq 373) chaining IRQs 376..383
[ 265.901733] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 265.903442] regulator: VUSB1V5: 1500 mV normal standby
[ 265.903747] regulator: VUSB1V8: 1800 mV normal standby
[ 265.904052] regulator: VUSB3V1: 3100 mV normal standby
[ 265.905578] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 265.906097] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 265.906463] regulator: VDAC: 1800 mV normal standby
[ 265.906768] regulator: VPLL2: 1800 mV normal standby
[ 265.907135] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 265.907562] regulator: VAUX3: 1800 mV normal standby
[ 265.907989] regulator: VAUX4: 1800 mV normal standby
[ 265.908203] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 265.917022] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 265.918609] Switching to clocksource 32k_counter
[ 265.930938] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 265.933715] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 265.933746] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 265.933898] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 1
[ 265.934051] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 265.934082] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 265.934082] usb usb1: Product: MUSB HDRC host driver
[ 265.934112] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 265.934143] usb usb1: SerialNumber: musb_hdrc
[ 265.935028] hub 1-0:1.0: USB hub found
[ 265.935089] hub 1-0:1.0: 1 port detected
[ 265.936401] NET: Registered protocol family 2
[ 265.936676] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 265.937316] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 265.937591] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 265.937713] TCP: Hash tables configured (established 8192 bind
8192)
[ 265.937744] TCP reno registered
[ 265.937744] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 265.937805] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 265.938079] NET: Registered protocol family 1
[ 265.938629] RPC: Registered udp transport module.
[ 265.938629] RPC: Registered tcp transport module.
[ 265.938659] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 265.939819] omap-iommu omap-iommu.0: isp registered
[ 265.941955] VFS: Disk quotas dquot_6.5.2
[ 265.942077] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 265.943572] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 265.944610] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 265.945648] msgmni has been set to 466
[ 265.951080] alg: No test for stdrng (krng)
[ 265.951446] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 254)
[ 265.951477] io scheduler noop registered
[ 265.951477] io scheduler deadline registered
[ 265.951660] io scheduler cfq registered (default)
[ 266.012756] OMAP DSS rev 2.0
[ 266.012817] OMAP DISPC rev 3.0
[ 266.012878] OMAP VENC rev 2
[ 266.013183] OMAP DSI rev 1.0
[ 266.353576] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 266.375610] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 266.396697] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 266.417785] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 266.953552] console [ttyS2] enabled
[ 266.966064] brd: module loaded
[ 266.973449] loop: module loaded
[ 266.978179] omap2-nand driver initializing
[ 266.982696] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 266.991943] cmdlinepart partition parsing not available
[ 266.997283] Creating 5 MTD partitions on "omap2-nand":
[ 267.002441] 0x000000000000-0x000000080000 : "X-Loader"
[ 267.009124] 0x000000080000-0x000000260000 : "U-Boot"
[ 267.015899] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 267.022247] 0x000000280000-0x000000680000 : "Kernel"
[ 267.029907] 0x000000680000-0x000010000000 : "File System"
[ 267.144439] usbcore: registered new interface driver catc
[ 267.149932] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 267.156036] usbcore: registered new interface driver kaweth
[ 267.161682] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 267.169372] usbcore: registered new interface driver pegasus
[ 267.175048] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 267.182098] usbcore: registered new interface driver rtl8150
[ 267.187957] usbcore: registered new interface driver asix
[ 267.193542] usbcore: registered new interface driver cdc_ether
[ 267.199493] usbcore: registered new interface driver dm9601
[ 267.205261] usbcore: registered new interface driver smsc95xx
[ 267.211181] usbcore: registered new interface driver gl620a
[ 267.216949] usbcore: registered new interface driver net1080
[ 267.222747] usbcore: registered new interface driver plusb
[ 267.228393] usbcore: registered new interface driver rndis_host
[ 267.234527] usbcore: registered new interface driver cdc_subset
[ 267.240631] usbcore: registered new interface driver zaurus
[ 267.246337] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 267.254608] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 267.261535] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 267.267669] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 2
[ 267.275329] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 267.293945] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 267.299865] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 267.306762] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 267.314056] usb usb2: Product: OMAP-EHCI Host Controller
[ 267.319458] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 267.324890] usb usb2: SerialNumber: ehci-omap.0
[ 267.330322] hub 2-0:1.0: USB hub found
[ 267.334197] hub 2-0:1.0: 3 ports detected
[ 267.364379] Initializing USB Mass Storage driver...
[ 267.369506] usbcore: registered new interface driver usb-storage
[ 267.375610] USB Mass Storage support registered.
[ 267.380737] mice: PS/2 mouse device common for all mice
[ 267.386444] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 267.394561] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 267.405395] i2c /dev entries driver
[ 267.409729] Linux video capture interface: v2.00
[ 267.414733] omap-iommu omap-iommu.0: isp: version 1.1
[ 267.421539] vpfe_init
[ 267.424530] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 267.536407] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 267.543487] Registered led device: beagleboard::usr0
[ 267.548706] Registered led device: beagleboard::usr1
[ 267.554901] Registered led device: beagleboard::pmu_stat
[ 267.562866] usbcore: registered new interface driver usbhid
[ 267.568511] usbhid: USB HID core driver
[ 267.572601] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 267.579681] usbcore: registered new interface driver snd-usb-audio
[ 267.660827] No device for DAI omap-mcbsp-dai-0
[ 267.665344] No device for DAI omap-mcbsp-dai-1
[ 267.669860] No device for DAI omap-mcbsp-dai-2
[ 267.674346] No device for DAI omap-mcbsp-dai-3
[ 267.678863] No device for DAI omap-mcbsp-dai-4
[ 267.683319] OMAP3 Beagle SoC init
[ 267.688476] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 267.701965] ALSA device list:
[ 267.704956] #0: omap3beagle (twl4030)
[ 267.709014] oprofile: using arm/armv7
[ 267.712951] TCP cubic registered
[ 267.716278] NET: Registered protocol family 17
[ 267.720794] NET: Registered protocol family 15
[ 267.725402] lib80211: common routines for IEEE802.11 drivers
[ 267.731140] ThumbEE CPU extension supported.
[ 267.735473] Power Management for TI OMAP3.
[ 267.740325] SmartReflex driver initialized
[ 267.755279] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 267.763946] registered taskstats version 1
[ 267.786956] Console: switching to colour frame buffer device 80x30
[ 267.812835] regulator_init_complete: incomplete constraints,
leaving VAUX3 on
[ 267.820312] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 267.828033] omap_vout omap_vout: probed for an unknown device
[ 267.834228] Waiting for root device /dev/mmcblk0p1...
[ 267.870941] mmc0: new high speed SDHC card at address 0001
[ 267.877075] mmcblk0: mmc0:0001 00000 7.41 GiB
[ 267.882049] mmcblk0: p1 p2
[ 267.944122] List of all partitions:
[ 267.947662] 1f00 512 mtdblock0 (driver?)
[ 267.952728] 1f01 1920 mtdblock1 (driver?)
[ 267.957763] 1f02 128 mtdblock2 (driver?)
[ 267.962799] 1f03 4096 mtdblock3 (driver?)
[ 267.967864] 1f04 255488 mtdblock4 (driver?)
[ 267.972869] b300 7772160 mmcblk0 driver: mmcblk
[ 267.978179] b301 160618 mmcblk0p1
[ 267.982543] b302 7606777 mmcblk0p2
[ 267.986846] No filesystem could mount root, tried: ext2
[ 267.992248] Kernel panic - not syncing: VFS: Unable to mount root
fs on unknown-block(179,1)
