Kernel Warning/crash using usb-serial device
Hi all,
Currently I am testing USB serial device with BeagleBoard(omap3) which
uses musb host controller. But I gets following Warnings every time
if I tries to open the /dev/ttyUSB0 using simple application which I
have written to open/read and write.
FYI, I currently tested with 2.6.29-rc5 and also 2.6.29-rc2, with no success.
What could be the possible reason? Is there any way, I can avoid this warning?
Thanks for your valuable help.
Shivdas
------------[ cut here ]------------
WARNING: at kernel/mutex.c:135 __mutex_lock_slowpath+0x6c/0x234()
Modules linked in: usbserial
[<c029d188>] (dump_stack+0x0/0x14) from [<c00516b4>] (warn_slowpath+0x68/0x9c)
[<c005164c>] (warn_slowpath+0x0/0x9c) from [<c029e0d0>]
(__mutex_lock_slowpath+0x6c/0x234)
r3:c039437c r2:00000000
r7:c787e9c0 r6:c7bc6c00 r5:c7bc6fb4 r4:c7bc6c00
[<c029e064>] (__mutex_lock_slowpath+0x0/0x234) from [<c029e2a8>]
(mutex_lock+0x10/0x14)
[<c029e298>] (mutex_lock+0x0/0x14) from [<c01a0d10>]
(echo_set_canon_col+0x1c/0x40)
[<c01a0cf4>] (echo_set_canon_col+0x0/0x40) from [<c01a2bcc>]
(n_tty_receive_buf+0xbdc/0x1074)
r5:00000000 r4:000000fe
[<c01a1ff0>] (n_tty_receive_buf+0x0/0x1074) from [<c01a513c>]
(flush_to_ldisc+0xf0/0x184)
[<c01a504c>] (flush_to_ldisc+0x0/0x184) from [<c01a520c>]
(tty_flip_buffer_push+0x3c/0x4c)
[<c01a51d0>] (tty_flip_buffer_push+0x0/0x4c) from [<bf0028b8>]
(usb_serial_generic_read_bulk_callback+0x12c/0x170 [usbserial])
[<bf00278c>] (usb_serial_generic_read_bulk_callback+0x0/0x170
[usbserial]) from [<c01e60b8>] (usb_hcd_giveback_urb+0xb0/0xfc)
r8:c78d88d8 r7:00000000 r6:c78d8800 r5:00000000 r4:c7851440
[<c01e6008>] (usb_hcd_giveback_urb+0x0/0xfc) from [<c01f8148>]
(__musb_giveback+0xf4/0x110)
r6:00000080 r5:c795c760 r4:c78d8800
[<c01f8054>] (__musb_giveback+0x0/0x110) from [<c01f825c>]
(musb_giveback+0xf8/0x1e0)
[<c01f8164>] (musb_giveback+0x0/0x1e0) from [<c01f8388>]
(musb_advance_schedule+0x44/0xcc)
[<c01f8344>] (musb_advance_schedule+0x0/0xcc) from [<c01f9814>]
(musb_host_rx+0x890/0x8fc)
r7:00000001 r6:00000001 r5:0000a203 r4:00000000
[<c01f8f84>] (musb_host_rx+0x0/0x8fc) from [<c01f5f3c>]
(musb_dma_completion+0x54/0x58)
[<c01f5ee8>] (musb_dma_completion+0x0/0x58) from [<c01fa2b8>]
(dma_controller_irq+0x158/0x1a4)
[<c01fa160>] (dma_controller_irq+0x0/0x1a4) from [<c0077a64>]
(handle_IRQ_event+0x3c/0x74)
[<c0077a28>] (handle_IRQ_event+0x0/0x74) from [<c0078e78>]
(handle_level_irq+0x94/0xec)
r7:0000005c r6:00000000 r5:0000005d r4:c036ceb0
[<c0078de4>] (handle_level_irq+0x0/0xec) from [<c002c058>]
(__exception_text_start+0x58/0x70)
r5:c7973e20 r4:0000005d
[<c002c000>] (__exception_text_start+0x0/0x70) from [<c002ca30>]
(__irq_svc+0x30/0x80)
Exception stack(0xc7973d70 to 0xc7973db8)
3d60: 00000001 00000000 0000021c 00000000
3d80: 40000113 00000000 00000000 0000005c 40069000 c7058000 00000200 c7973dcc
3da0: 00000214 c7973db8 c01fa140 c01f67e8 60000113 ffffffff
r5:d8200000 r4:ffffffff
[<c01f6780>] (generic_interrupt+0x0/0xa4) from [<c0077a64>]
r4:c7925de0
r7:c7055968 r6:c787e9c0 r5:0000005c r4:c036ce74
r5:00000000 r4:0000005c
Exception stack(0xc7973e20 to 0xc7973e68)
3e20: c7959ae0 000001a4 c70f1800 c0371978 00000069 00000000 c787e9c0 c7055968
3e40: 40069000 c7058000 00000200 c7973ebc c7059000 c7973e68 c0032d24 c008e01c
3e60: 60000113 ffffffff
[<c008df50>] (handle_mm_fault+0x0/0x5c4) from [<c0032d24>]
(do_page_fault+0xe8/0x24c)
[<c0032c3c>] (do_page_fault+0x0/0x24c) from [<c0032f2c>]
(do_translation_fault+0x18/0x7c)
[<c0032f14>] (do_translation_fault+0x0/0x7c) from [<c002c1b4>]
(do_PrefetchAbort+0x18/0x1c)
r7:00000000 r6:00000000 r5:00000000 r4:ffffffff
[<c002c19c>] (do_PrefetchAbort+0x0/0x1c) from [<c002cd80>]
(ret_from_exception+0x0/0x10)
Exception stack(0xc7973fb0 to 0xc7973ff8)
3fa0: 0000983c bea0df20 00000003 0000983c
3fc0: 40023e08 00000000 00000000 00000000 00000000 00000000 40024000 bea0dcd4
3fe0: 40069518 bea0dbb0 000093e0 40069518 60000010 ffffffff
---[ end trace b3b574d010a6d594 ]---
Connected to /dev/ttyUSB0
Serial speed set to 115200.
Hi all,
I am troubled with the same problem, too.
Is there the person having the information of this problem?
mizo.
2009/2/21 Greg KH <greg@kroah.com>
