Kernels hang while booting from MMC
I have a Beagleboard C5 and I am stuck at the stage where Angstrom
loading screen has showed up but it hangs. The progress bar seems to
be staying at 60% completion forever.
Here was what I did. I followed the instructions from both sites.
http://www.angstrom-distribution.org/demo/beagleboard/
http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning
I noticed from http://www.angstrom-distribution.org/demo/beagleboard/
that there are two versions of MLO and u-boot, and uImage and there
are 3 versions of Anstrom-...bz2 files. It is unclear to me which
versions are up-to-date.
Here is what I put in the SD card,
For 1st partition:
1. http://angstrom.s3.amazonaws.com/demo/beagleboard/MLO
2. http://angstrom.s3.amazonaws.com/demo/beagleboard/u-boot.bin
3. http://angstrom.s3.amazonaws.com/demo/beagleboard/uImage
For 2nd partition
1. http://angstrom.s3.amazonaws.com/demo/beagleboard/Angstrom-Beagleboard-demo-image-glibc-ipk-2011.1-beagleboard.rootfs.tar.bz2
Now, the u-boot commands are a little tricky. I am not sure if I
should follow the u-boot commands at
http://angstrom.s3.amazonaws.com/demo/beagleboard/index.html
or
or both.
When I only use the uboot command from http://angstrom.s3.amazonaws.com/demo/beagleboard/index.html,
which are:
mmc init
mmc rescan 0
fatload mmc 0 82000000 MLO
nand unlock
nandecc hw
nand erase 0 80000
nand write 82000000 0 20000
nand write 82000000 20000 20000
nand write 82000000 40000 20000
nand write 82000000 60000 20000
fatload mmc 0 0x80200000 u-boot.bin
nand unlock
nand ecc sw
nandecc sw
nand erase 80000 170000
nand write 0x80200000 80000 170000
I would see the message that the kernel is loading............
but it would hang there.
When I use the boot command from http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning,
I would get error messages.
Can someone please comment where the latest sources of information are
for Beagleboard C5 and which commands I should really use?
Any suggestions would be really helpful!
Thank you!
Auds
Please refer the below link
http://processors.wiki.ti.com/index.php/Kernel_-_Common_Problems_Booting_Linux
forther more please follow links
http://elinux.org/BeagleBoard#U-Boot
http://elinux.org/BeagleBoardBeginners
Regards
~Eswar
