mmc0 is current device
micro SD card found
SD/MMC found on device 0
** File not found uEnv.txt **
gpio: pin 55 (gpio 55) value is 1 ** Invalid partition 2 **
To force a boot from the microSD card, delete the MLO file in the FAT partition of the eMMC.
You can access this when the board is connected over the USB cable and it appears as a thumbdrive.
But there is no windows partition … normally the script /debian-7.7-console-armhf-2014-10-29# ./setup_sdcard.sh --mmc /dev/sdb --dtb beaglebone
392 bytes read in 53 ms (6.8 KiB/s)
6967192 bytes read in 1188 ms (5.6 MiB/s)
2109770 bytes read in 387 ms (5.2 MiB/s)
84819 bytes read in 138 ms (599.6 KiB/s)
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Loading Ramdisk to 9f034000, end 9f23714a … OK
Using Device Tree in place at 80f80000, end 80f97b52
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
cpsw, usb_ether
micro SD card found
760 bytes read in 8 ms (92.8 KiB/s)
Running uenvcmd …
