Is there a work-around for this?
I am using a BeagleBoard-xM revC. Thanks in advance,
-Ed
http://downloads.angstrom-distribution.org/demo/beagleboard/untested/
-rw-r–r-- 1 z3 z3 100530739 2012-12-19 10:58 Angstrom-systemd-GNOME-image-eglibc-ipk-v2012.05-beagleboard.rootfs.tar.bz2
-rw-r–r-- 1 z3 z3 42960 2012-12-19 10:56 MLO
-rw-r–r-- 1 z3 z3 12833522 2012-12-19 10:57 modules-3.2.28-r122a-beagleboard.tgz
-rw-r–r-- 1 z3 z3 338172 2012-12-19 10:56 u-boot.img
-rw-r–r-- 1 z3 z3 4388808 2012-12-19 10:57 uImage-3.2.28-r122a-beagleboard-20121009164219.bin
Terminal:
Started Load Kernel Modules [ OK ]
Started Debug File System [ OK ]
Started Remount API VFS [ 19.975006] udevd[58]: starting version 182
[ OK ]
Started udev Kernel Device Manager [ OK ]
Started Temporary Directory [ OK ]
Starting FUSE Control File System…
Started Configuration File System [ OK ]
Started FUSE Control File System [ OK ]
Started File System Check on Root Device [ OK ]
Starting Remount Root FS…
[ 20.226501] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Started Remount Root FS [ OK ]
Starting Recreate Volatile Files and Directories…
Starting Load Random Seed…
Started Machine ID first boot configure [ OK ]
Starting Run pending postinsts…
Started udev Coldplug all Devices [ OK ]
Started Recreate Volatile Files and Directories [ OK ]
Started Load Random Seed [ OK ]
systemd-fsck[49]: Angstrom: clean, 28099/499712 files, 169199/1998084 blocks
[ 20.757873] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 21.760070] rtc-ds1307: probe of 2-0068 failed with error -5
[ 22.175598] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 22.643646] OMAP3 Beagle/Devkit8000 SoC init
[ 22.882202] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 23.256591] smsc95xx v1.0.4
[ 23.499877] smsc95xx 1-2.1:1.0: eth0: register ‘smsc95xx’ at usb-ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, 12:0a:a6:9b:d2:6c
[ 23.512023] usbcore: registered new interface driver smsc95xx
Hangs at last line.
