Hello all !
Just been trying out the latest angstrom beaglebone black image ( http://downloads.angstrom-distribution.org/demo/beaglebone/ ) but I’ve been noticing a couple of problems. First of all though (hurrah!) I did manage finally to get a display from my beaglebone black and the latest angstrom image; previous to this the only one that had worked is the older version on the beaglebone black’s internal storage.
I managed to get it going by (after some research) looking up EDIDs. I copied off the edid file from the older (working) angstrom image on the internal storage, copied it over to a normal desktop PC and ran parse-edid on it. If it helps btw heres my xorg.conf;
Section “Module”
Load “extmod”
Load “dbe”
Load “glx”
Load “freetype”
Load “type1”
Load “record”
Load “dri”
EndSection
#Section “Monitor”
Identifier “Builtin Default Monitor”
#EndSection
Section “Monitor”
Block type: 2:0 3:fc
Identifier “HDMI to VGA”
VendorName “EXP”
ModelName “HDMI to VGA”
Block type: 2:0 3:fd
HorizSync 31-83
VertRefresh 56-76
Max dot clock (video bandwidth) 180 MHz
DPMS capabilities: Active off:yes Suspend:no Standby:no
Mode “1024x768” # vfreq 60.004Hz, hfreq 48.363kHz
DotClock 65.000000
HTimings 1024 1048 1184 1344
VTimings 768 771 777 806
EndMode
Mode “1280x720” # vfreq 60.000Hz, hfreq 45.000kHz
DotClock 74.250000
HTimings 1280 1390 1430 1650
VTimings 720 725 730 750
Flags “+HSync” “+VSync”
EndMode
EndSection
Section “Device”
Identifier “Builtin Default fbdev Device 0”
Driver “modesetting”
EndSection
Section “Screen”
Identifier “Builtin Default fbdev Screen 0”
Device “Builtin Default fbdev Device 0”
Monitor “HDMI to VGA”
DefaultDepth 16
EndSection
Section “ServerLayout”
Identifier “Builtin Default Layout”
Screen “Builtin Default fbdev Screen 0”
EndSection
Might work/help out someone else out there with a VGA to HDMI converter!
There’s just one problem though. It feels almost as if my beaglebone black with the latest angstrom image is almost running as if it were only operating at half speed! The old angstrom on the internal storage - loaded up fast even firefox. The latest version (I should point out, prehaps this is the root cause of my problem though I am not sure - the newer image is being run from a micro SD card) seems very slow - in fact I tried to load the GIMP and the beagleboard hung!
Could it be I possibly have the slowest micro sd card in the universe or maybe there’s something else going wrong?
ljones
