Latest Image 08/24 Stretch Expand File Sys method fails
Decided to try out the latest image posted Aug 24 and the method of expanding the
file system to use the full size of an sd card fails at the git pull step.
debian@beaglebone:/var/lib/cloud9$ cd
debian@beaglebone:~$ pwd
/home/debian
debian@beaglebone:~$ uname -a
Linux beaglebone 4.4.83-ti-r119 #1 SMP Thu Aug 17 06:39:24 UTC 2017 armv7l GNU/Linux
debian@beaglebone:~$ cat /etc/dogtag
BeagleBoard.org Debian Image 2017-08-24
debian@beaglebone:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 217M 0 217M 0% /dev
tmpfs 49M 4.9M 44M 10% /run
/dev/mmcblk0p1 3.3G 1.6G 1.5G 51% /
tmpfs 244M 0 244M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 244M 0 244M 0% /sys/fs/cgroup
debian@beaglebone:~$ cd /opt/scripts/tools/
debian@beaglebone:/opt/scripts/tools$ git pull
fatal: unable to access ‘https://github.com/RobertCNelson/boot-scripts/’: Could not resolve host: github.com
debian@beaglebone:/opt/scripts/tools$ sudo git pull
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for debian:
Tom
just run:
sudo ./grow_partition.sh
Robert
Said command not found
/home/debian
debian@beaglebone:~$ sudo ./grow_partition.sh
sudo: ./grow_partition.sh: command not found
Robert
Works now, I guess I was like the CPU that does exactly what you tell it to do not what you thought
you told it to do LOL
Off to test if the Adafruit BBIO issue got fixed
https://forums.adafruit.com/viewtopic.php?f=49&t=105847
Thank’s for the quick reply
Tom
