Latest Linux
Has anyone been able to boot 2.6.32 kernel ?
http://gitorious.org/~felipec/linux-omap/felipec
I built the kernel, and executed on Beagleboard Rev B5,
After uncompressing linux it just hangs
Robin
I'm not sure if taking someone's private git is a good plan.
There is also an official omap git. Not sure whether that has 2.6.32 in it.
afaik openembedded does not support .32 yet. Some patches are needed
to get it running.
Frans
to get it running.
Frans
I am getting patches through the linux-omap list and at times
discussions about them. Is there a repository somewhere where they could
be obtained as a lump that could be applied with the patch command?
Robin
This is with a uImage built from the yesterday's git pull. I shall have
a look to see if there is a later u-boot to try.
Texas Instruments X-Loader 1.4.2 (Aug 8 2008 - 16:59:05)
Reading boot sector
Booting from mmc
U-Boot 2009.01-dirty (Feb 19 2009 - 12:23:21)
I2C: ready
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
Using default environment
MUSB: using high speed
In: serial usbtty
Out: serial usbtty
Err: serial usbtty
Board revision C
Serial #6b22000300000000040323090d00a00a
reading boot.scr
679 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
reading x-load.bin.ift
19840 bytes read
***** Replacing x-load *****
Usage:
nand - NAND sub-system
HW ECC selected
NAND erase: device 0 offset 0x0, size 0x80000
^MErasing at 0x0 -- 25% complete.^MErasing at 0x20000 -- 50%
complete.^MErasing at 0x40000 -- 75% complete.^MErasing at 0x60000 --
100% complete.
OK
NAND write: device 0 offset 0x0, size 0x20000
131072 bytes written: OK
NAND write: device 0 offset 0x20000, size 0x20000
NAND write: device 0 offset 0x40000, size 0x20000
NAND write: device 0 offset 0x60000, size 0x20000
reading u-boot-f.bin
** Unable to read "u-boot-f.bin" from mmc 0:1 **
***** Erasing environment settings *****
Usage:
NAND erase: device 0 offset 0x160000, size 0x20000
^MErasing at 0x160000 -- 100% complete.
OK
reading normal.scr
603 bytes read
***** Executing normal.scr *****
reading uImage.bin
1447692 bytes read
***** Kernel: /dev/mmcblk0p1/uImage.bin *****
reading ramdisk.gz
** Unable to read "ramdisk.gz" from mmc 0:1 **
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 80200000 ...
   Image Name: Linux-2.6.32-rc5
   Data Size: 1447628 Bytes = 1.4 MB
   Load Address: 00008000
   Entry Point: 00008000
   Verifying Checksum ... OK
   Loading Kernel Image ...
Regards
Sid.
Hi Sid,
Give this patchset a try/take a look:
https://code.launchpad.net/~beagleboard-kernel/+junk/2.6-mainline
2.6.32-rc5 with otg & dss2 currently working on b's and c's... ehci
is broken somewhere on rev c's..
Just disable "micrel-eth" and enable "fixup" in the patch.sh script..
(expansion board i'm working on, doesn't seem to boot on boards
missing the adapter...)
Use the tag v2.6.32-felipec1
vmjl
