Hi All,
I plan on creating a customer version of the LCD3 cape and I’m having trouble understanding a couple of things in the schematic (https://github.com/CircuitCo/BeagleBone-LCD3-RevA1/blob/master/BeagleBone-LCD3-RevA1-schematic.pdf?raw=true)
- I see quite a bit of DIN and I understand it means Do Not Install but does that mean I’m simply replacing that part with a wire or by removing it I’m now causing a gap.
- Why is the PWM signal connected to the EN pin in the boost converter but also connected to the Slow Start pin? Why is connecting to the enable pin not enough?
