Hello
The PWM for the backlight which controls the LCD4 / LCD7 / 4DCAPE-43, is this controlled from the Kernel for from the dts file located in /lib/firmware/ ?
I have tried to edit the dts file in /lib/firmware/ and edited the PWM frequency to be 200Hz from the standard 2Khz, and compiled the dts file into the dtbo file, however it wasn’t picked up on next reboot.
I am just learning this stuff so I don’t really know what I am missing.
Someone told me that the ‘standard capes’ may be controlled from the kernel rather than from the dts files in the /lib/firmware/ folder, and the /lib/firmware/ folder isnt even mounted at the point the kernel version kicks in.
Is this true?
If it is, does it require a kernel rebuild in order to change something like the PWM frequency?
Is it possible to apply a patch or something rather than having to rebuild the kernel? If so, how is this done?
I even went to the extent of changing the EEPROM content of one of the CAPES I have, and then edited a dts file with the same name and part number inside, and then tried to force the cape to be loaded after it had started up by using the uEnv.txt, but that didn’t work either.
I am stumped.
I am just wanting a quick fix to do some testing.
Please if anyone could help I would really appreciate it.
Regards
Terry
