Juanjo <sierralta@gmail.com> [12-09-22 16:36]:
Indeed I used xinput_calibrator since it is run when Angstrom boot first
time but it doesn't fix the problem but I did not changed my xorg.conf as
the program said since it is suppose to apply the changes immediately and
the xorg changes are for next reboot.
And after the opkg upgrade the xinput_calibrator works different it seems
because it doesn't mention Xorg.conf files
> Juanjo <sier...@gmail.com <javascript:>> [12-09-22 03:04]:
> > Just got my LCD7 cape for my BB
> > Problem is that I tried with a brand new BB A6 rev. and the mouse is
> moving
> > erratic when I log in Gnome. I'm using the stock Amsntrong image and
> even
> > made "opkg upgrade". But the strange thing that the pointer works fine
> on
> > GDM login screen but as soon as I log in it just jumps to the corners.
> > I mean fine on GDM because I cannot reach the corners with my fingers
> but
> > at least I can click buttons but once I log in is basically useless. And
> I
> > did run the calibration app; seems like a software bug once some of the
> > GNOME stuff loads.
> > Anyone got the same problem ? This is brand new gear, BB A6 and LCD7 A3.
> > Thanks !
> Hi Juanjo,
> no panic!
> The touchscreen has to be calibrated before using it. Since I am not
> using gnome, I am not sure, what the name of gnome's calibration
> utility is -- in my case it is xinput_calibrator.
> Good luck!
> mcc
Hi Juanjo,
I switched to gentoo on the beaglebone. It is better documented I
think. I am using Robert Nelsons kernel, which works fine.
Furthermore I compiled X11 and openbox for my "desktop".
In this environment I run the calibrator which prints a snippet
of code then, which has then been put into /etc/X11/xorg.conf.d/.
The file itsself is named 99-calibration.conf with this content:
---->8-----
Section "InputClass"
Identifier "calibration"
MatchProduct "ti-tsc-adcc"
Option "Calibration" "50 3988 306 3797"
EndSection
---->8-----
The values may vary to yours...
When X11 starts, it reads this file and calibrates the touchscreen.
But the calibration is only active after restarting X11 once.
You dont need to reboot. Often it is sufficient to "ZAP" (if
activated) X11 or to log out and in again.
Just try it. Calibrate your screen by manually starting the
calibrator, insert the output of the application as described
above and restart X11.
As long you have an low level access (ssh/serial console) the worst
thing, which may happen is, that it does not work, which is the
current state 8)
HTH!
Good luck!
Have a nice weekend!
Best regards,
mcc
