Is this the right mode:
#git pull ; ./oebb.sh update
#MACHINE=beaglebone ./oebb.sh config beaglebone
#MACHINE=beaglebone ./oebb.sh update
#MACHINE=beaglebone ./oebb.sh bitbake systemd-image
I did previous steps and the same result:
ERROR: Error executing a python function in /home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/openembedded-core/meta/recipes-extended/pam/libpam_1.1.5.bb:
IOError: [Errno 2] No such file or directory: ‘/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/openembedded-core/meta/recipes-extended/pam/libpam/./pam.d/*’
ERROR: The stack trace of python calls that resulted in this exception/failure was:
ERROR: File “base_do_fetch”, line 18, in
ERROR:
ERROR: File “base_do_fetch”, line 13, in base_do_fetch
ERROR:
ERROR: File “/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/bitbake/lib/bb/fetch2/init.py”, line 1006, in download
ERROR: update_stamp(u, ud, self.d)
ERROR:
ERROR: File “/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/bitbake/lib/bb/fetch2/init.py”, line 335, in update_stamp
ERROR: verify_checksum(u, ud, d)
ERROR:
ERROR: File “/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/bitbake/lib/bb/fetch2/init.py”, line 277, in verify_checksum
ERROR: md5data = bb.utils.md5_file(ud.localpath)
ERROR:
ERROR: File “/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/bitbake/lib/bb/utils.py”, line 362, in md5_file
ERROR: for line in open(filename):
ERROR:
ERROR: The code that was being executed was:
ERROR: 0014: except bb.fetch2.BBFetchException, e:
ERROR: 0015: raise bb.build.FuncFailed(e)
ERROR: 0016:
ERROR: 0017:
ERROR: *** 0018:base_do_fetch(d)
ERROR: 0019:
ERROR: (file: ‘base_do_fetch’, lineno: 18, function: )
ERROR: 0009: bb.data.update_data(localdata)
ERROR: 0010:
ERROR: 0011: try:
ERROR: 0012: fetcher = bb.fetch2.Fetch(src_uri, localdata)
ERROR: *** 0013: fetcher.download()
ERROR: 0016:
ERROR: 0017:
ERROR: (file: ‘base_do_fetch’, lineno: 13, function: base_do_fetch)
ERROR: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/libpam-1.1.5-r3/temp/log.do_fetch.22170
NOTE: package libpam-1.1.5-r3: task do_fetch: Failed
ERROR: Task 818 (/home/ramon/Damarc/beaglebone/Angstrom-distribution-setup-scripts-69bb9ed/sources/openembedded-core/meta/recipes-extended/pam/libpam_1.1.5.bb, do_fetch) failed with exit code ‘1’
Waiting for 1 running tasks to finish:
0: git-native-1.7.10.2-r0 do_populate_sysroot (pid 22169)
NOTE: package git-native-1.7.10.2-r0: task do_populate_sysroot: Succeeded
NOTE: Tasks Summary: Attempted 988 tasks of which 985 didn’t need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 WARNING messages shown.
Summary: There were 37 ERROR messages shown, returning a non-zero exit code.
Sorry, I don’t want to disturb, but is my first time with beaglebone and I’m a little confused.
Thanks very much.
