Hello. I try to use cross compilation under windows.
My board is BeagleBone Black with Angstrom.
I downloaded toolchain from http://sysprogs.com/files/gnutoolchains/beaglebone/beaglebone-gcc4.7.3.exe.
If I compile programm with gcc, after deploing I can run it with out problems. If i use g++, after deploing I
receive libstdc++.so.6 not found.
I search this library on board it is exiest.
If i compile the same program directly on board using g++ it runs perfectly.
If I use ldd on programm compiled on windows mashine, ldd writes libstdc++.so.6 not found.
If I use ldd on programm that compiled on board ldd shows pathes to librarys.
I checked /etc/ld.so.conf all possible pathes is writen.
I tryed to copy libstdc++.so.6 to angsterm library pathes, but it is still not found after run programm.
Do you have any ideas?
