I am trying to use the PRU-ICSS with beaglebone, at this point I am just trying to run some examples from https://github.com/beagleboard/am335x_pru_package. The drive is loading with no error but I can’t find the device uio0.
I am running the kernel 3.8.13. Checking the modules I have:
lsmod
Module Size Used by Not tainted
uio_pruss 3702 0
uio 6540 1 uio_pruss
unix 23436 12
Under /sys I have :
find /sys -name uio
/sys/class/uio ← this is empty
/sys/module/uio
ls -la /sys/module/uio
total 0
drwxr-xr-x 5 root root 0 Jan 1 00:25 .
drwxr-xr-x 46 root root 0 Jan 1 00:00 …
-r–r--r-- 1 root root 4096 Jan 1 00:42 coresize
drwxr-xr-x 2 root root 0 Jan 1 00:42 holders
-r–r--r-- 1 root root 4096 Jan 1 00:42 initsize
-r–r--r-- 1 root root 4096 Jan 1 00:42 initstate
drwxr-xr-x 2 root root 0 Jan 1 00:42 notes
-r–r--r-- 1 root root 4096 Jan 1 00:42 refcnt
drwxr-xr-x 2 root root 0 Jan 1 00:42 sections
-r–r--r-- 1 root root 4096 Jan 1 00:42 srcversion
-r–r--r-- 1 root root 4096 Jan 1 00:42 taint
–w------- 1 root root 4096 Jan 1 00:25 uevent
Somebody has experience with PRUSS to give me a help?
Before running any applications, you need to enable PRU module in
device tree. This can be easily done by loading a DT overlay. There is
an overlay in Angstrom which enables PRUSS, but if I remember
correctly, it conflicts with HDMI.
Try the following:
1. Download the overlay from
https://github.com/piranha32/IOoo/blob/master/dts/tlc5946-00A0.dts
2. Compile it: dtc -O dtb -o tlc5946-00A0.dtbo -b 0 -@ tlc5946-00A0.dts
3. Copy the .dtbo file to /lib/firmware on beaglebone
4. Load the overlay: echo tlc5946 > /sys/devices/bone_capemgr.*/slots
At this point you should have working PRUSS
j.
GitHub - beagleboard/am335x_pru_package. The drive is loading
with no error but I can't find the device uio0.
<snip>
You need to load a device tree overlay that enables the PRU.
Try (as root):
echo BB-BONE-PRU-01 > /sys/devices/bone_capemgr.*/slots
I am having problem to make the kernel use the overlay. I will continue with this tomorrow.
Thank you so far.
This is the point that I stuck last night.
I don’t have /sys/devices/bone_capemgr.*/slots; this is what I have:
ls -la /sys/devices/
total 0
drwxr-xr-x 14 root root 0 Jan 1 00:00 .
dr-xr-xr-x 12 root root 0 Jan 1 00:00 …
drwxr-xr-x 3 root root 0 Jan 1 00:00 44e10800.pinmux
drwxr-xr-x 3 root root 0 Jan 1 00:00 ARMv7 Cortex-A8
drwxr-xr-x 3 root root 0 Jan 1 00:00 bone_capemgr.7
drwxr-xr-x 3 root root 0 Jan 1 00:00 breakpoint
drwxr-xr-x 4 root root 0 Jan 1 00:00 fixedregulator.8
drwxr-xr-x 28 root root 0 Jan 1 00:00 ocp.2
drwxr-xr-x 13 root root 0 Jan 1 00:00 platform
drwxr-xr-x 4 root root 0 Jan 1 00:00 soc.0
drwxr-xr-x 3 root root 0 Jan 1 00:00 software
drwxr-xr-x 4 root root 0 Jan 1 00:00 system
drwxr-xr-x 3 root root 0 Jan 1 00:00 tracepoint
drwxr-xr-x 15 root root 0 Jan 1 00:00 virtual
And under bone_capemgr.7
ls -la /sys/devices/bone_capemgr.7/
total 0
drwxr-xr-x 3 root root 0 Jan 1 00:00 .
drwxr-xr-x 14 root root 0 Jan 1 00:00 …
-r–r--r-- 1 root root 4096 Jan 1 00:01 modalias
drwxr-xr-x 2 root root 0 Jan 1 00:01 power
lrwxrwxrwx 1 root root 0 Jan 1 00:00 subsystem → …/…/bus/platform
-rw-r–r-- 1 root root 4096 Jan 1 00:00 uevent
Maybe something is missing at kernel. Below is the .config file.
Which distro do you use? PRUSS works ootb with Angstrom.
j.
I am using the https://github.com/beagleboard/kernel 3.8 from RobertCNelson with buildroot.
I think you may be missing this:
CONFIG_CAPE_BEAGLEBONE =y
j.
I think that you catch one problem and now I have this message that I don’t remember have seen in the past.
I am going to dig on it.
Again, thank you so far.
[ 1.759324] brd: module loaded
[ 1.788054] loop: module loaded
[ 1.792984] bone-capemgr bone_capemgr.7: Failed to get baseboard memory access
[ 1.801164] bone-capemgr: probe of bone_capemgr.7 failed with error -524
[ 1.815053] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.823596] OneNAND driver initializing
I have never seen this one either. Does the board boot?
j.
Yes, everything is working.
I am going to recompile the kernel after clean, I have been doing changes over changes.
What beaglebone kernel version do we know for sure that PRU is working ?
I got the version 3.8 based on instruction from beagleborad.org but maybe I should be using another one.
There is another thing that confuse me; there is a kernel version from TI at http://downloads.ti.com/sitara_linux/esd/AM335xSDK/latest/index_FDS.html
and another from https://github.com/beagleboard/kernel. What is the difference?
This is the point in the capemgr.c that I am having the problem.
/* grab the memory accessor of the eeprom */
bbrd->macc = i2c_eeprom_get_memory_accessor(bbrd->client);
if (IS_ERR_OR_NULL(bbrd->macc)) {
dev_err(&pdev->dev, "Failed to get "
“baseboard memory accessor\n”);
ret = bbrd->macc == NULL ? -ENODEV :
PTR_ERR(bbrd->macc);
bbrd->macc = NULL;
goto err_exit;
I found some messages that may have relation with part of the code above (this is a guess).
[ 0.531788] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.533755] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.539204] omap_i2c 4819c000.i2c: unable to select pin group
That's what my board is running:
Linux beaglebone 3.8.13 #1 SMP Tue Jun 25 08:17:15 EDT 2013 armv7l GNU/Linux
j.
Do you mind to send me your .config ???
I am using omap2plus_defconfig and later I include the uio and uio_pru but maybe I need something else that I can’t see.
Considering that I was using buildroot these are the steps that someone should follow:
~$ git clone git://github.com/beagleboard/kernel.git && cd kernel ~/kernel$ git checkout 3.8
~/kernel$ ./patch.sh
~/kernel$ cp configs/beaglebone kernel/arch/arm/configs/beaglebone_defconfig
~/kernel$ wget http://arago-project.org/git/projects/?p=am33x-cm3.git;a=blob_plain;f=bin/am335x-pm-firmware.bin;hb=HEAD -O kernel/firmware/am335x-pm-firmware.bin
~/kernel$ tar --exclude=‘.git’ -cvjf linux-am335x-3.8.13.tar.bz2 kernel
Copy the linux tarball to /dl/
Configure the kernel at buildroot:
7.1 Kernel version: am335x-3.8.13
7.2 Kernel configuration: Using defconfig
7.3 Defconfig name: beaglebone
7.4 Kernel binary format: uImage
7.5 Load address: 0x80008000 (that is what I am using but doesn’t need to be this one)
7.6 Set “Device tree support”
7.6.1 Device tree source: Use a device tree present in the kernel.
7.6.2 Device Tree Source file names: am335x-bone
- Configure “Bootloaders”
8.1 Set “U-Boot”
8.2 U-Boot board name: am335x_evm
8.3 Set “U-Boot SPL support”
8.3.1 U-Boot SPL target name: MLO
Next are the instructions to enable the PRU
- Download the overlay from https://github.com/piranha32/IOoo/blob/master/dts/tlc5946-00A0.dts
- Compile it: dtc -O dtb -o tlc5946-00A0.dtbo -b 0 -@ tlc5946-00A0.dts
- Copy the .dtbo file to /lib/firmware on beaglebone
- Load the overlay: echo tlc5946 > /sys/devices/bone_capemgr.*/slots
I think that this summarize the most important steps to make PRU-ICSS work using buidlroot on beaglebone.
