load a bmp splash image via u-boot
Has anyone tried to load a bmp splash image via u-boot.
I tried using SD flash instead of tftp as http://www.denx.de/wiki/DULG/UBootSplashScreen,
but not successfully, it hangs. Maybe fatload doesn't work as I
expect.
mmc init 0;
fatload mmc 0 0x41F80000 my.bmp;
Kai <kaijun61@yahoo.com> [2010-03-18 09:17:54]:
but not successfully, it hangs. Maybe fatload doesn't work as I expect.
Have you read all the information on that URL? There's 'To enable splash
screen support, you have to add a "#define CONFIG_SPLASH_SCREEN"', do you have
it in your U-boot?
mmc init 0;
Where did you get that video memory address from? I think, that it's wrong.
BTW, I don't know if it helps you, but I've working RLE splash screen in
U-boot. You need to create 1280x720 image in 256(or less) colors in Gimp and
then convert it using gimp2rle[1] to RLE format to header logo.h[2] file. Than
you need to modify U-boot source in beagle.c[3], include "logo.h"[4] add
dss_init() function[5] and call it in misc_init_r() [6]. Recompile U-boot.
That's all.
-- ynezz
1. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/gimp2rle/gimp2rle.c
2. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/logo.h
3. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/beagle.c
4. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/beagle.c#L40
5. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/beagle.c#L128
6. http://github.com/ynezz/beagleboard-uboot-logo/blob/master/beagle.c#L254
Kai <kaiju...@yahoo.com> [2010-03-18 09:17:54]:
> I tried using SD flash instead of tftp ashttp://www.denx.de/wiki/DULG/UBootSplashScreen,
it in your U-boot?
Yes, I have. I have defined CONFIG_SPLASH_SCREEN in beagleboard config
file.
> mmc init 0;
That's all.
I have done that. But once linux kernel is uncompressed, the splash
screen is corrupted.
I guess why it is corrupted is the splash is in 0x80500000 that is
allocated for the kernel.
The code was one year's old. dss_init() seems to have some same code
as display_init().
So that is why I try u-boot approach, it can suppress console output.
Kai <kaijun61@yahoo.com> [2010-03-19 03:17:47]:
I think that this is because of the linux framebuffer logo.
-- ynezz
How do you remove beagleboard logo at the upper left corner of screen?
Kai <kaijun61@yahoo.com> [2010-03-19 04:16:09]:
Please, would you stop that top posting? Thanks.
http://www.google.com/search?q=linux+kernel+config+boot+logo
-- ynezz
