Load cape and ai64 device tree
The way I read this from Ti sysconfig it appears the load cape P9_42 Sink1 must be controled by pru and not directly via gpio.
/* This file was auto-generated by TI PinMux on 8/7/2024 at 8:50:55 PM. */
/* This file should only be used as a reference. Some pins/peripherals, */
/* depending on your use case, may need additional configuration. */
&main_pmx0 {
	mycpsw9g1_pins_default: mycpsw9g1-default-pins {
		pinctrl-single,pins = <
			J721E_IOPAD(0xdc, PIN_INPUT, 9) /* (AJ28) PRG0_PRU0_GPO11.CLKOUT */
	test_pin1_pins_default: test_pin1-default-pins {
			J721E_IOPAD(0x1f0, PIN_OUTPUT_PULLUP, 7) /* (AC2) UART0_CTSn.GPIO0_123 */
I reads like the input goes into pru then this implies pru controls the output pin. Have not had any luck getting control of the pins using lgpiod. This seems like it might be the reason why??
@foxsquirrel ,
I am not inclined to say anything about PRU stuff now. Um, did you change the mode and offsets?
P.S. I was trying with this Cape a while back to update things.
compatible = "beagle,j721e-beagleboneai64", "ti,j721e";
    fragment@0 {
        target = <&main_pmx0>;
        __overlay__ {
            pinmux_P9_42_gpio: pinmux_P9_42_gpio {
                    0x01f0 0x0018  /* P9_42 as GPIO0_123, OUTPUT, PULLUP */
You are trying to configure P9_42 as a GPIO pin ?
P9_42 is one of the double pad pins. Are you sure the other pad is set as an input ?
Not looked at the macro J721E_IOPAD but I would guess that the mux bits are the bottom 4 bits ? In which case aren’t you setting mux mode 8 which is undefined for pad AC2. Even if it isn’t the bottom 4 bits, you are not setting mode 7 as it would require 3 bits set to 1.
That explains why Ti sysconfig generates the input for the pru.
Going to reinstall a fresh image, the board has several locations for the overlays. The one that has been used is /boot/firmware/overlays/ it also has /boot/dtbs/5.10.168-ti-arm64-r115/ti/overlays. Not sure which path is the correct one?
You are right, It should be 0x07.
I also found the overlays in /boot/firmware/ti/.
I am not sure if your board has the /ti/ section on it in that file or not but keep it up.
P.S. I usually use /boot/firmware/overlays/ for extlinux.conf on the BBAI-64. Have you succeeded yet or are you starting slowly. And…are you planning on succeeding to completion? I started to use the BBAI-64 a bit more due to the Motor Cape and I am hoping people will still develop around this board, i.e. as it is pretty fast for embedded use, can handle high heat, and boots super fast.
It depends on how much time I have to spend on getting the device tree up. We have the same code running on beagley-ai and bbb, bbbi with telemetry buried to measure latency in the gpio and track outliers. To get any meaningful information the code has to be exactly the same, only changes need to be lines and gpiochip.
Not sure what is up with ai64, I got bealgley -ai up and running the rpi 8 channel relay board (din rail mounted version) and the load cape is running on bbb and bbbi boards. The ai64 has been an off and on relationship…
@foxsquirrel ,
From what I read on the discord servers, some people are developing still for this board.
P.S. I am being patient, i.e. as I would also like to see other boards with Capes work. Let me see if I can quote anyone here:
No, with the beagley-ai, we figured out a way to set the default pinmux.
Then can libgpiod directly for pull up pull down high low...
[10:18 PM]
I've been backporting that to the AI 64 in the play
So, who knows? I think in time, all Capes may work well with the board.
It should work fine, big issue is the mux with other I/O. The load cape is one of the most useful to those building mechanical stuff. Even if the transistors are limited in current capacity you can still drive relays with it. Way better than trying to drive a relay directly from gpio pins. If memory is correct, the official BBB load cape overlay is running our BBB & BBBI boards. It was just overlooked in the later branches of BBDT. The beagly-ai we did here.
I am waiting on big news…
Now, will I get it or will another person attain the “news” before me? Who knows? Waiting in solitude as usual!
P.S. There is the COMMS Cape too for those of us who like to build around old world technologies and incorporate them into current specs. and tech. Mouser still sells the Motor Cape and other Capes thankfully. I just found them again while searching for ideas on builds around the newer boards. And of course, I will need to get my hands on some electronics, e.g. UC2950T Texas Instruments | Integrated Circuits (ICs) | DigiKey and 74LVC1G57. I am still a sucker for building and learning how to do things with ease and/or difficulty.
This would be a good basis, I really like the din rail mount and the 8 relays. It has a many other possibilities. You will need to use the RPI 5 cooling fan with this board. It is fan ready out of the box, just plug it in.
Neat…you made that piece of electronics? Busy-busy-busy!
P.S. I see BBAI-64 now. Neat.
@RobertCNelson What pin mux information are you using. I can apply labels then the pin mux I am using does not appear to be correct and it breaks so the labels will not apply.
fred@ai64:~$ gpioinfo
gpiochip0 - 84 lines:
	line   0:      unnamed       "BOOT"   input   active-low [used]
	line   1:      unnamed       unused   input  active-high
	line   2:      unnamed       unused   input  active-high
	line   3:      unnamed       unused   input  active-high
	line   4:      unnamed      "POWER"   input   active-low [used]
	line   5:      unnamed       unused   input  active-high
	line   6:      unnamed       unused   input  active-high
	line   7:      unnamed       unused   input  active-high
	line   8:      unnamed       unused   input  active-high
	line   9:      unnamed       unused   input  active-high
	line  10:      unnamed       unused   input  active-high
	line  11:      unnamed       unused   input  active-high
	line  12:      unnamed       unused   input  active-high
	line  13:      unnamed       unused   input  active-high
	line  14:      unnamed       unused   input  active-high
	line  15:      unnamed       unused   input  active-high
	line  16:      unnamed       unused   input  active-high
	line  17:      unnamed       unused   input  active-high
	line  18:      unnamed       unused   input  active-high
	line  19:      unnamed       unused   input  active-high
	line  20:      unnamed       unused   input  active-high
	line  21:      unnamed       unused   input  active-high
	line  22:      unnamed       unused   input  active-high
	line  23:      unnamed       unused   input  active-high
	line  24:      unnamed       unused   input  active-high
	line  25:      unnamed       unused   input  active-high
	line  26:      unnamed       unused   input  active-high
	line  27:      unnamed       unused   input  active-high
	line  28:      unnamed       unused   input  active-high
	line  29:      unnamed       unused   input  active-high
	line  30:      unnamed       unused   input  active-high
	line  31:      unnamed       unused   input  active-high
	line  32:      unnamed       unused   input  active-high
	line  33:      unnamed       unused   input  active-high
	line  34:      unnamed       unused   input  active-high
	line  35:      unnamed       unused   input  active-high
	line  36:      unnamed       unused   input  active-high
	line  37:      unnamed       unused   input  active-high
	line  38:      unnamed       unused   input  active-high
	line  39:      unnamed       unused   input  active-high
	line  40:      unnamed       unused   input  active-high
	line  41:      unnamed       unused   input  active-high
	line  42:      unnamed       unused   input  active-high
	line  43:      unnamed       unused   input  active-high
	line  44:      unnamed       unused   input  active-high
	line  45:      unnamed       unused   input  active-high
	line  46:      unnamed       unused   input  active-high
	line  47:      unnamed       unused   input  active-high
	line  48:      unnamed       unused   input  active-high
	line  49:      unnamed       unused   input  active-high
	line  50:      unnamed       unused   input  active-high
	line  51:      unnamed       unused   input  active-high
	line  52:      unnamed       unused   input  active-high
	line  53:      unnamed       unused   input  active-high
	line  54:      unnamed       unused   input  active-high
	line  55:      unnamed       unused   input  active-high
	line  56:      unnamed       unused   input  active-high
	line  57:      unnamed       unused   input  active-high
	line  58:      unnamed       unused   input  active-high
	line  59:      unnamed       unused   input  active-high
	line  60:      unnamed       unused   input  active-high
	line  61:      unnamed       unused   input  active-high
	line  62:      unnamed       unused   input  active-high
	line  63:      unnamed       unused   input  active-high
	line  64:      unnamed       unused   input  active-high
	line  65:      unnamed       unused   input  active-high
	line  66:      unnamed       unused   input  active-high
	line  67:      unnamed       unused   input  active-high
	line  68:      unnamed       unused   input  active-high
	line  69:      unnamed       unused   input  active-high
	line  70:      unnamed       unused   input  active-high
	line  71:      unnamed       unused   input  active-high
	line  72:      unnamed       unused   input  active-high
	line  73:      unnamed       unused   input  active-high
	line  74:      unnamed       unused   input  active-high
	line  75:      unnamed       unused   input  active-high
	line  76:      unnamed       unused   input  active-high
	line  77:      unnamed       unused   input  active-high
	line  78:      unnamed       unused   input  active-high
	line  79:      unnamed       unused   input  active-high
	line  80:      unnamed       unused   input  active-high
	line  81:      unnamed       unused   input  active-high
	line  82:      unnamed       unused   input  active-high
	line  83:      unnamed       unused   input  active-high
gpiochip1 - 128 lines:
	line   0: "test_gpio0"       unused   input  active-high
	line   1: "test_gpio1"       unused   input  active-high
	line   2: "test_gpio2"       unused   input  active-high
	line   3: "test_gpio3"       unused   input  active-high
	line   4: "test_gpio4"       unused   input  active-high
	line  22:      unnamed      "reset"  output  active-high [used]
	line  49:      unnamed "regulator-5" output active-high [used]
	line  82:      unnamed "regulator-3" output active-high [used]
	line  84:      unnamed       unused   input  active-high
	line  85:      unnamed       unused   input  active-high
	line  86:      unnamed       unused   input  active-high
	line  87:      unnamed       unused   input  active-high
	line  88:      unnamed       unused   input  active-high
	line  89:      unnamed       unused   input  active-high
	line  90:      unnamed       unused   input  active-high
	line  91:      unnamed       unused   input  active-high
	line  92:      unnamed       unused   input  active-high
	line  93:      unnamed       unused   input  active-high
	line  94:      unnamed       unused   input  active-high
	line  95:      unnamed "beaglebone:green:usr1" output active-high [used]
	line  96:      unnamed "beaglebone:green:usr0" output active-high [used]
	line  97:      unnamed "beaglebone:green:usr2" output active-high [used]
	line  98:      unnamed       unused   input  active-high
	line  99:      unnamed       unused   input  active-high
	line 100:      unnamed       unused   input  active-high
	line 101:      unnamed       unused   input  active-high
	line 102:      unnamed       unused   input  active-high
	line 103:      unnamed       unused   input  active-high
	line 104:      unnamed       unused   input  active-high
	line 105:      unnamed       unused   input  active-high
	line 106:      unnamed       unused   input  active-high
	line 107:      unnamed       unused   input  active-high
	line 108:      unnamed       unused   input  active-high
	line 109:      unnamed "beaglebone:green:usr4" output active-high [used]
	line 110:      unnamed "beaglebone:green:usr3" output active-high [used]
	line 111:      unnamed       unused   input  active-high
	line 112:      unnamed       unused   input  active-high
	line 113:      unnamed       unused   input  active-high
	line 114:      unnamed       unused   input  active-high
	line 115:      unnamed       unused   input  active-high
	line 116:      unnamed       unused   input  active-high
	line 117:      unnamed   "tlv71033"  output  active-high [used]
	line 118:      unnamed       unused   input  active-high
	line 119:      unnamed       unused   input  active-high
	line 120:      unnamed       unused   input  active-high
	line 121:      unnamed       unused   input  active-high
	line 122:      unnamed       unused   input  active-high
	line 123:      unnamed       unused   input  active-high
	line 124:      unnamed       unused   input  active-high
	line 125:      unnamed       unused   input  active-high
	line 126:      unnamed       unused   input  active-high
	line 127:      unnamed       unused   input  active-high
gpiochip2 - 36 lines:
	line   0:        "ch1"       unused   input  active-high
	line   1:        "ch2"       unused   input  active-high
	line   2:        "ch3"       unused   input  active-high
	line   3:        "ch4"  "typec-dir"   input   active-low [used]
	line   4:        "ch5"       unused   input  active-high
	line   5:        "ch6"       unused   input  active-high
	line   6:        "ch7"       unused   input  active-high
	line   7:        "ch8"       unused   input  active-high
fred@ai64:~$
/dts-v1/;
/plugin/;
    compatible = "beagle,j721e-beagleboneai64";
    fragment@0 {
        target = <&main_gpio0>;
        __overlay__ {
            status = "okay";
            gpio-line-names = "test_gpio0", "test_gpio1", "test_gpio2", "test_gpio3", "test_gpio4";
    fragment@1 {
        target = <&main_gpio1>;
        __overlay__ {
            status = "okay";
            gpio-line-names = "ch1", "ch2", "ch3", "ch4", "ch5", "ch6", "ch7", "ch8";
dtc -O dtb -o test-gpio-overlay.dtbo -b 0 -@ test-gpio-overlay.dts
This is the macro I am using from k3 config
#define J721E_IOPAD(pa, val, muxmode)		(((pa) & 0x1fff)) ((val) | (muxmode))
