Loading a Device Tree Overlay (dtbo file)
I have a BBB. I am using Buildroot to create a custom build. My kernel is 6.1.80.
I have a dtbo file that I placed in /lib/firmware.
My uEnv.txt file for u-boot is as follows:
bootpart=0:1
devtype=mmc
bootdir=
bootfile=zImage
bootpartition=mmcblk0p2
console=ttyS0,115200n8
loadaddr=0x82000000
fdtaddr=0x88000000
set_mmc1=if test $board_name = A33515BB; then setenv bootpartition mmcblk1p2; fi
set_bootargs=setenv bootargs console=${console} root=/dev/${bootpartition} rw rootfstype=ext4 rootwait
uenvcmd=run set_mmc1; run set_bootargs;run loadimage;run loadfdt;printenv bootargs;bootz ${loadaddr} - ${fdtaddr}
uname_r=6.1.x
enable_uboot_overlays=1
dtb_overlay_addr0=/lib/firmware/adau1761-beaglebone-black-i2c-i2s.dtbo
The overlay does not appear to loaded by u-boot. I ran lsmod, and the overlay is not listed. If I run:
dmseg | grep ADAU
I get no return.
Any ideas on what I can try?
at beginning of boot, does it say retrieving uEnv.txt or extlinux.conf the dtbo need to go in the one that is being retrieved.
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
135 bytes read in 4 ms (32.2 KiB/s)
1:	beaglebone-buildroot
Retrieving file: /zImage
11031040 bytes read in 691 ms (15.2 MiB/s)
append: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Retrieving file: /am335x-boneblack.dtb
99078 bytes read in 8 ms (11.8 MiB/s)
## Flattened Device Tree blob at 88000000
   Loading Device Tree to 8ffe4000, end 8ffff305 ... OK
That is interesting. It does appear to retrieve extlinux.conf instead of uEnv.txt. I thought uEnv.txt was linked to uboot. I did notice the extlinux.conf file, but didn’t know what it was for. It does appear to load the BBB device tree, so I will see if I can get it to load my overlay. Am I in control of which file is used (extlinux.conf or uEnv.txt)? Should they contain the same information? If there is a doc you can point me to, that would be great!
no docs that i know of, about a year or two ago they changed from uEnv.txt to extlinux.conf. both were read by u-boot. as for which is used, older u-boots will still use uEnv.txt where newer ones will use extlinux.conf. don’t think you have any control which is used, uEnv.txt is just scripting that extends u-boot script, so if you have special needs for this script, you will just need to patch the script in u-boot.
GL
