I cannot load my .out file to the Beagle Board i am using.
I am using:
Code Composer 3.3
Beagle Board -xMA
Angstrom as OS on the Beagleboard
XDS510plus Emulator
I used the "Spectrum Digital USB510" configuration file from section
"DM3730 and DM3725" on website: http://processors.wiki.ti.com/index.php/OMAP_and_Sitara_CCS_support
I am able to connect to the Cortex processor and after that I can use
GELIVA2200 ->IVA22_startup to the release the DSP. Then I can connect
to the DSP. But when openening Code Composer and I want to load the
program to the DSP, the following message appears in the putput
cosole:
“Trouble Writing Memory Block at 0xfc00 on Page 0 of Length 0x200:
Error 0x00000002/-1190 Error during: Memory, The DTDMA memory request
is not serviced by the HW memory system. This could be caused by the
memory address specified does not exist in the specified memory/cache
level.“
A couple of things I still dont get:
Why are there distinct entries in the CCSTudio Parallel Debug manager
for ARM9 and CortexA, I thought there is only one Cortex-A9 processor?
And I am also not familiar with the usage of gel files.
The config file I am using automatically uses the gel files:
"omap3430_c64plus.gel" for the DSP and
"omap3430_arm9.gel" for the ARM processor
Is this right at all, because the BB is not a OMAP3430?
I hope anyone has an idea.
Thx and regards
Sven
