I’m running a BBG with Ubuntu on external microSD-card (the one from BeagleBoardUbuntu - eLinux.org ).
When no network cable is connected to the BBG, the boot time is quite long, it comes up with a text
A start job is running for Raise network interfaces (39s / 5min 2s)
The first time value is counting and it really takes minutes…
How can I avoid this delay and let it continue without network when no cable is plugged?
Thanks!
edit /etc/network/interfaces
and comment out the two "eth0" lines..
But this disables the network interface permanently, not only when no cable is plugged?
There is a package called ifplugd which monitors the connection and only activates the connection when a cable is plugged into the socket and the electrical connection to another system (or router/switch) is established.
David
Simple installation of ifplugd does not do the job - what else has to be done?
Have you configured it? It needs to know which interfaces it controls, and you need to make sure that these interfaces are not auto-started. Have you read the README in /usr/share/doc/ifplugd ?
David
2016-10-26 12:22 GMT+02:00 David Goodenough <david.goodenough@linkchoose.co.uk>:
David
