Low capture rate
Hi sir,
Thanks for your suggestions
1. We tried with low resolution (i.e 320x240) eventhough capture rate
is still the same.
2. We did not declare any separate variable for reading FPS. How to
decrease FPS? Please give some links related to this topic.
3. We are using sandisk class 4 microSD .
Do you have any details on the performance?
Hi sir,
Here is my code and its performance in Beagle board.
#include <iostream>
#include <stdio.h>
using namespace std;
using namespace cv;
void help()
    cout << "\nThis program demonstrates the haar cascade recognizer
\n"
        "this classifier can recognize many ~rigid objects, it's most
known use is for faces.\n"
      "Usage:\n"
      "./facedetect [--cascade=<cascade_path> this is the primary
trained classifier such as frontal face]\n"
        " [--nested-cascade[=nested_cascade_path this an optional
secondary classifier such as eyes]]\n"
        " [--scale=<image scale greater or equal to 1, try 1.3 for
\n"
        " [filename|camera_index]\n\n"
        "see facedetect.cmd for one call:\n"
        "./facedetect --cascade=\"../../data/haarcascades/
haarcascade_frontalface_alt.xml\" --nested-cascade=\"../../data/
haarcascades/haarcascade_eye.xml\" --scale=1.3 \n"
      "Hit any key to quit.\n"
        "Using OpenCV version %s\n" << CV_VERSION << "\n"
        << endl;
void detectAndDraw( Mat& img,
                   CascadeClassifier& cascade, CascadeClassifier&
nestedCascade,
                   double scale);
String cascadeName =
"../../data/haarcascades/haarcascade_frontalface_alt.xml";
String nestedCascadeName =
"../../data/haarcascades/haarcascade_eye_tree_eyeglasses.xml";
int main( int argc, const char** argv )
    CvCapture* capture = 0;
    Mat frame, frameCopy, image;
    const String scaleOpt = "--scale=";
    size_t scaleOptLen = scaleOpt.length();
    const String cascadeOpt = "--cascade=";
    size_t cascadeOptLen = cascadeOpt.length();
    const String nestedCascadeOpt = "--nested-cascade";
    size_t nestedCascadeOptLen = nestedCascadeOpt.length();
    String inputName;
    help();
    CascadeClassifier cascade, nestedCascade;
    double scale = 1;
    for( int i = 1; i < argc; i++ )
      cout << "Processing " << i << " " << argv[i] << endl;
        if( cascadeOpt.compare( 0, cascadeOptLen, argv[i],
cascadeOptLen ) == 0 )
            cascadeName.assign( argv[i] + cascadeOptLen );
            cout << " from which we have cascadeName= " <<
cascadeName << endl;
        else if( nestedCascadeOpt.compare( 0, nestedCascadeOptLen,
argv[i], nestedCascadeOptLen ) == 0 )
            if( argv[i][nestedCascadeOpt.length()] == '=' )
                nestedCascadeName.assign( argv[i] +
nestedCascadeOpt.length() + 1 );
            if( !nestedCascade.load( nestedCascadeName ) )
                cerr << "WARNING: Could not load classifier cascade
for nested objects" << endl;
        else if( scaleOpt.compare( 0, scaleOptLen, argv[i],
scaleOptLen ) == 0 )
            if( !sscanf( argv[i] + scaleOpt.length(), "%lf", &scale )
scale < 1 )
                scale = 1;
            cout << " from which we read scale = " << scale << endl;
        else if( argv[i][0] == '-' )
            cerr << "WARNING: Unknown option %s" << argv[i] << endl;
        else
            inputName.assign( argv[i] );
    if( !cascade.load( cascadeName ) )
        cerr << "ERROR: Could not load classifier cascade" << endl;
        cerr << "Usage: facedetect [--cascade=<cascade_path>]\n"
            " [--nested-cascade[=nested_cascade_path]]\n"
            " [--scale[=<image scale>\n"
            " [filename|camera_index]\n" << endl ;
        return -1;
    if( inputName.empty() || (isdigit(inputName.c_str()[0]) &&
inputName.c_str()[1] == '\0') )
        capture = cvCaptureFromCAM( inputName.empty() ? 0 :
inputName.c_str()[0] - '0' );
        int c = inputName.empty() ? 0 : inputName.c_str()[0] - '0' ;
        if(!capture) cout << "Capture from CAM " << c << " didn't
work" << endl;
    else if( inputName.size() )
        image = imread( inputName, 1 );
        if( image.empty() )
            capture = cvCaptureFromAVI( inputName.c_str() );
            if(!capture) cout << "Capture from AVI didn't work" <<
endl;
    else
        image = imread( "lena.jpg", 1 );
        if(image.empty()) cout << "Couldn't read lena.jpg" << endl;
    cvNamedWindow( "result", 1 );
    if( capture )
      cout << "In capture ..." << endl;
        for(;:wink:
            IplImage* iplImg = cvQueryFrame( capture );
            frame = iplImg;
            if( frame.empty() )
                break;
            if( iplImg->origin == IPL_ORIGIN_TL )
                frame.copyTo( frameCopy );
            else
                flip( frame, frameCopy, 0 );
            detectAndDraw( frameCopy, cascade, nestedCascade, scale );
            if( waitKey( 10 ) >= 0 )
                goto _cleanup_;
        waitKey(0);
_cleanup_:
        cvReleaseCapture( &capture );
    else
      cout << "In image read" << endl;
        if( !image.empty() )
            detectAndDraw( image, cascade, nestedCascade, scale );
            waitKey(0);
        else if( !inputName.empty() )
            /* assume it is a text file containing the
            list of the image filenames to be processed - one per line
            FILE* f = fopen( inputName.c_str(), "rt" );
            if( f )
                char buf[1000+1];
                while( fgets( buf, 1000, f ) )
                    int len = (int)strlen(buf), c;
                    while( len > 0 && isspace(buf[len-1]) )
                        len--;
                    buf[len] = '\0';
                    cout << "file " << buf << endl;
                    image = imread( buf, 1 );
scale );
                        c = waitKey(0);
                        if( c == 27 || c == 'q' || c == 'Q' )
                            break;
                    else
                      cerr << "Aw snap, couldn't read image " << buf <<
endl;
                fclose(f);
    cvDestroyWindow("result");
    return 0;
nestedCascade,
                   double scale)
    int i = 0;
    double t = 0;
    vector<Rect> faces;
    const static Scalar colors[] = { CV_RGB(0,0,255),
        CV_RGB(0,128,255),
        CV_RGB(0,255,255),
        CV_RGB(0,255,0),
        CV_RGB(255,128,0),
        CV_RGB(255,255,0),
        CV_RGB(255,0,0),
        CV_RGB(255,0,255)} ;
    Mat gray, smallImg( cvRound (img.rows/scale), cvRound(img.cols/
scale), CV_8UC1 );
    cvtColor( img, gray, CV_BGR2GRAY );
    resize( gray, smallImg, smallImg.size(), 0, 0, INTER_LINEAR );
    equalizeHist( smallImg, smallImg );
    t = (double)cvGetTickCount();
    cascade.detectMultiScale( smallImg, faces,
        1.1, 2, 0
        //|CV_HAAR_FIND_BIGGEST_OBJECT
        //|CV_HAAR_DO_ROUGH_SEARCH
