Hi at all,
I want use the main console that I use to boot my beaglebone and start my aplication,
but I don’t know how to disable the shell, because my aplication and shell use the same console,
and when push a key confuse between my aplicacion and shell.
I’m not expert in linux, please tell me, how can I do that?, disable service of shell and login in the process of booting.
Thank you in advance.
Maybe you should tell us a bit more about your "my_application" and
your configuration.
But as always, linux offers many solutions.
if "my_application" is non-interactive you can simply push it to background.
eg:
nohup my_application &
or
my_application > my_application.log &
see eg http://en.wikipedia.org/wiki/Nohup
But my favorite solution is the following:
Connect your Beaglebone to your lan and connect to it over ssh (from
Windows with putty). Then you can open as many (almost) terminals as
you want.
-didi
