I have been looking everywhere for this but have not yet found anything that makes sense - to me of little linux knowledge.
Narcissus generates image files of Angstom tyles in a .tar.gz format.
I am used to using windows + a .img format.
How do you achieve generate an SDcard from this .tar.gz image?
I can use either Windows or Linux - but can somebody please point me towards how to do this.
Hi Gerald,
...the images are "cat"ed or "dd"ed (Linux Host) to the
SD card, which includes the partition table to be written.
But do I have to do, if I want to write the image to a 16GB card and
not to the default 4GB card, which comes with my beaglebone?
Best regards,
mcc
Gerald Coley <gerald@beagleboard.org> [12-08-15 18:20]:
Just write the 4 GB image to your card. Then, the simple thing to do
would be to use something like GParted[1] to expand the main partition
and file system to fill the entire 16 GB card.
[1]:http://gparted.org/
-Andrew
BeagleBone is 4G. Writing a 4G image to a 16G card will give yo an expensive 4G card.
Hi Gerald,
well spotted!
...which is exactly the reason for asking my question
Gerald Coley <gerald@beagleboard.org> [12-08-15 18:48]:
I have already visited the support site.
http://circuitco.com/support/index.php?title=BeagleBone#Image_Files
What I cannot (as yet) get my head around is that nearly all the image files I have used - whether linux or windows based are labelled something like *******.img.tar or *******.img - or ********.tar.gz and if necessary to decompress in windows produce a ******.img file which is a straight ‘write’ with Win32DiskImager or in linux to provide a group of files/folders that include some files that help with the build - take Ubuntu or Debian Wheezy .
The http://elinux.org/BeagleBoardUbuntu for example - where you use the script sudo ./setup_sdcard.sh --mmc /dev/sdX --uboot “board” after downloading and decompressing it.
The Narcissus generated image file that I downloaded did not seem to include the ‘script’ parts like this included or at least I certainly could not seem to get past that stage?
decompress in windows produce a ******.img file which is a straight 'write'
script sudo ./setup_sdcard.sh --mmc /dev/sdX --uboot "board" after
the 'script' parts like this included or at least I certainly could not seem
In that situation, Angstrom has a script to just format the sd card,
and relies on your to dump the *.tar to the correct partition..
Grap the 'mksdcard.txt' script..
And then follow:
"How to Unpack and Boot the Demo Image - the hard way"
(on the same http page)
