Hey
I currently have some image processing code on Matlab that I would
like to implement on the Beagleboard, I don't think it supports Matlab
though. Can anyone please tell me how to convert this to C code that
will work on the Beagle?
Thanks in advance
You may want to take a look at Octave[1]. It is an open-source Matlab
clone which should run just fine on the BeagleBoard. Otherwise, I would
probably look into porting the code to Python using PIL[2]. If this
doesn't suffice then you'd need to probably fall back to C which is no
different than writing C for any other platform.
- Ben
[1] http://www.gnu.org/software/octave/
[2] http://www.pythonware.com/products/pil/
Hhere are the first two links from a Google search for “matlab generate c code”.
A discussion about embedded Matlab:
www.edaboard.com/thread111807.html
and the MathWorks documentation:
www.mathworks.com/support/tech-notes/1600/1622.html
Hope this helps.
You may find matlab code generation for Beagleboard at
http://users.ox.ac.uk/~engs1058/projects/BeagleboardMatlab.html
As an example, it illustrate a random number geneartor written in Matlab was converted into C codes, build by the CodeSourcery cross-compiler and finally run at the Beagleboard
Is it possible that you update this link?
