Hi, I'm looking at using the beadle board for a project where I
require the output res to be set to 3216x1920. This is for a custom
bit of hardware which has a funny res. I'm looking to use the beagle
board just to display a couple of images nothing fancy. Do you think
its feasible?
its feasible?
That's bigger than the maximum resolution supported by the DSS.
And the built in video controller will do a maximum resolution of 1400x1050 at 50 Hz refresh rate.
The 2048x2048 is the “maximum” video surface (you can scroll the screen around to display a “viewport” into this 2048x2048 surface), but the video DAC hardware is restricted to the 1400x1050 50 Hertz vertical refresh rate, 32 bits per pixel layout.
Gerald wrote:
No. Max in theory is 2048x2048 for the BeagleBoard-xM…
"Fredric J. Einstein" <feinstei@frontier.com> writes:
The 2048x2048 is the "maximum" video surface (you can scroll the screen
around to display a "viewport" into this 2048x2048 surface), but the video
