MCspi in dsp for beagle board
   How i can access the Mcspi1 registers in dsp side.Could you please
tell me .
bhimesh
tell me .
If I am not mistaken, the DSP has access to all the IO registers, so
you should be able to just use it, check the TRM for the address
mapping...
Vladimir is spot-on.
Just a little remark: If you're working with an OS on the ARM just make
sure that you don't use the SPI from the ARM. E.g. in Linux disable
kernel functionality for SPI. Otherwise all kinds of strange things will
happen.
Nils
From: beagleboard@googlegroups.com [mailto:beagleboard@googlegroups.com]
On Behalf Of Nils Pipenbrinck
Sent: Tuesday, February 07, 2012 10:49 AM
To: beagleboard@googlegroups.com
Subject: Re: [beagleboard] MCspi in dsp for beagle board
>> Hi,
>> please tell me .
> mapping...
sure that
you don't use the SPI from the ARM. E.g. in Linux disable kernel
functionality for
SPI. Otherwise all kinds of strange things will happen.
Here is a response I got from TI when I asked about using DSP side drivers:
