McSPI with REV C
First of all, thank you all for the thread
http://groups.google.com/group/beagleboard/browse_thread/thread/42988f0e14db0f01/90cfddb68a827347?#90cfddb68a827347
I followed it and successfully made bidirectional SPI work for BB.
However, I have following issues:
1. It works fine for Rev B board, but USB host port is disabled in
Rev. C board. Is there a pinmux conf. conflict between Rev B and C?
2. Is there a simple way to enable McSPI on Rev C board? There was
discussion going in the past to configure the pinmux through kernel
and keep u-boot untouched.
Thanks in advance,
Kunal
There is a difference in the Rev C and Rev B pin assignments on the expansion connector. This is documented in the System Reference Manual.
http://beagleboard.org/static/BBSRM_latest.pdf
I have a rev A, I really need to get a rev C and use that for SPI stuff :slight_smile:
Philip
I guess dinosaurs do still roam the earth afterall!!
What rev did the expansion connector change that impacts the pinmux occur?
Philip
B7 and earlier VS. Rev C. It is documented in the Rev C3 System Reference Manual.
hi all
i Working on the omap and i need to communicate with adc through spi
protocol ,
on the kernel i enabled the user spase spi
and i donot get on the /dev the spixx driver.
do u can help?
