Measuring USB serial throughput and USB data rate ?
Hi !
I want to test “what is USB data rate beagle board supports?”
and want to test the throughput of USB serial?
Does someone have an idea of " Test tool in linux for USB serial throughput measurement"?
and “procedure or tool for measuring USB data rate”.
Thanks for your help!
Shivdas
USB data rate to what device? If you're talking about a memory stick, you
could just time how long it takes to copy a file of a known size to or from
the stick.
Chris
Hi !
I want to measure data rate of USB Serial…
For memory stick, I know that we can use “SiSandra”, a windows tool for throughput measurement…
For more clear…
I will open /dev/ttyUSB0 on host and do “cat 10KB_file.txt > /dev/ttyUSB0”
and want to know in how much time this file, is transfered totally to the device…
Do you have any idea of such tool in windows or linux.
Shivdas
liuez
2008-10-15
发件人: Shivdas Gujare
发送时间: 2008-10-15 12:58:36
收件人: beagleboard@googlegroups.com
抄送:
主题: [beagleboard] Re: Measuring USB serial throughput and USB data rate ?
Hi !
I want to measure data rate of USB Serial..
For memory stick, I know that we can use "SiSandra", a windows tool for throughput measurement..
For more clear...
I will open /dev/ttyUSB0 on host and do "cat 10KB_file.txt > /dev/ttyUSB0"
and want to know in how much time this file, is transfered totally to the device..
Shivdas
