I have been trying to build the Poky Linux distribution with the Texas
Instruments overlay as described in http://elinux.org/BeagleBoard/Poky.
After going through the tutorial and running the bitbake omap-image-
min-gst command the image starts to build. After half an hour or so
the build will stop saying it cant fetch the kernel v2.6.28-felipec1.
After reading around I understand that this kernel is no longer
available and 2.6.32-felipec1 is now the preferred version.
I altered the linux-beagle_git.bb to try and fetch the new kernel as
below, but it still throws an error (error is at very bottom. Any help
would be much appreciated - Thanks.
ROVIDES="virtual/dspbridge-module"
RPROVIDES="virtual/dspbridge-module"
require linux-omap.inc
PR = "r0"
DEFAULT_PREFERENCE = "1"
FILESDIR = "${FILE_DIRNAME}/${PN}-git/${MACHINE}"
S = "${WORKDIR}/git"
#SRC_URI = "git://github.com/felipec/linux-omap.git;protocol=git"
#SRCREV = "9f40e7784c723e23175c6c2c50256fd010e559c4"
#PV = "2.6.28-felipec1+${PR}+git${SRCREV}"
SRC_URI = "git://gitorious.org/~felipec/linux-omap/
felipec.git;branch=fc-omap-2.6.32;protocol=git"
SRCREV = "166fba316e30952d5a474bc8a5c916ed1f4d2bb3"
PV = "2.6.32-felipec1+git${SRCREV}"
NOTE: Handling BitBake files: | (1183/1183) [100 %]
NOTE: Parsing finished. 1121 cached, 0 parsed, 62 skipped, 0 masked.
NOTE: Cache is clean, not saving.
NOTE: build 201007010010: started
OE Build Configuration:
BB_VERSION = "1.8.11"
METADATA_REVISION = "5728"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "beagleboard"
DISTRO = "tilinux"
DISTRO_VERSION = "0.1"
TARGET_FPU = "soft"
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version
1.1.99.1+gitrd23aad31338e7d869d878d5aa1b6b91d20287005 of libx11-native
not available (for item libx11-native)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 514 of 2105 (ID: 408, /home/stuart/pokypurple2/poky/
meta-texasinstruments/packages/linux/linux-beagle_git.bb, do_fetch)
NOTE: package linux-beagle-2.6.32-
felipec1+git166fba316e30952d5a474bc8a5c916ed1f4d2bb3: started
felipec1+git166fba316e30952d5a474bc8a5c916ed1f4d2bb3-r0: task
do_fetch: started
NOTE: fetch
http://pokylinux.org/sources/git_gitorious.org.~felipec.linux-omap.felipec.git_166fba316e30952d5a474bc8a5c916ed1f4d2bb3.tar.gz
--2010-07-01 00:10:48--
Resolving pokylinux.org... 70.86.75.186
Connecting to pokylinux.org|70.86.75.186|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2010-07-01 00:10:48 ERROR 404: Not Found.
NOTE: fetch http://pokylinux.org/sources/git_gitorious.org.~felipec.linux-omap.felipec.git.tar.gz
--2010-07-01 00:10:48-- http://pokylinux.org/sources/git_gitorious.org.~felipec.linux-omap.felipec.git.tar.gz
2010-07-01 00:10:49 ERROR 404: Not Found.
Initialized empty Git repository in /home/stuart/pokypurple2/poky/
sources/git/gitorious.org.~felipec.linux-omap.felipec.git/.git/
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
fetch-pack from 'git://gitorious.org/~felipec/linux-omap/felipec.git'
failed.
NOTE: Task failed: Fetch failed: Fetch command export GIT_CONFIG=/home/
stuart/pokypurple2/poky/build/tmp/staging/i686-linux/usr/etc/
gitconfig; export PATH=/home/stuart/pokypurple2/poky/build/tmp/staging/
i686-linux/usr/bin/beagleboard-none-linux-gnueabi:/home/stuart/
pokypurple2/poky/build/tmp/staging/i686-linux/usr/sbin:/home/stuart/
pokypurple2/poky/build/tmp/staging/i686-linux/usr/bin:/home/stuart/
pokypurple2/poky/build/tmp/cross/armv7a/bin:/home/stuart/pokypurple2/
poky/build/tmp/staging/i686-linux/sbin:/home/stuart/pokypurple2/poky/
build/tmp/staging/i686-linux/bin::/usr/local/csl/arm-2008q3/bin:/home/
stuart/pokypurple2/poky/bitbake//bin/:/home/stuart/pokypurple2/poky/
scripts:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/
usr/games; git clone -n git://gitorious.org/~felipec/linux-omap/felipec.git
/home/stuart/pokypurple2/poky/sources/git/gitorious.org.~felipec.linux-
omap.felipec.git failed with signal 1, output:
fatal: early EOF
failed.
do_fetch: failed
ERROR: TaskFailed event exception, aborting
felipec1+git166fba316e30952d5a474bc8a5c916ed1f4d2bb3: failed
ERROR: Build of /home/stuart/pokypurple2/poky/meta-texasinstruments/
packages/linux/linux-beagle_git.bb do_fetch failed
ERROR: Task 408 (/home/stuart/pokypurple2/poky/meta-texasinstruments/
packages/linux/linux-beagle_git.bb, do_fetch) failed
NOTE: Tasks Summary: Attempted 513 tasks of which 513 didn't need to
be rerun and 1 failed.
ERROR: '/home/stuart/pokypurple2/poky/meta-texasinstruments/packages/
linux/linux-beagle_git.bb' failed
NOTE: build 201007010010: completed
