I am running Ubuntu 13.10 build from here:
http://elinux.org/BeagleBoardUbuntu#eMMC:_BeagleBone_Black
and followed the instructions to set up the micro SD card as extra storage space, here:
http://elinux.org/Beagleboard:MicroSD_As_Extra_Storage
Now, I’m rather new to linux commands and new to the BBB. I may have misunderstood what I’ve been reading, but when I use the command df I get:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk1p2 1738184 1176724 471496 72% /
none 4 0 4 0% /sys/fs/cgroup
udev 252148 4 252144 1% /dev
tmpfs 50756 232 50524 1% /run
none 5120 0 5120 0% /run/lock
none 253760 0 253760 0% /run/shm
none 102400 0 102400 0% /run/user
/dev/mmcblk1p1 72098 19742 52356 28% /boot/uboot
If I understand correctly, the micro SD card is mmcblk0p1 and it isn’t listed here. I’d like to set it up so the micro SD card is extra space that I can store and run programs on, not just store files, which I think is what this is saying as df shows the file system disk usage. I can’t even figure out how to get to the micro SD card though I know it’s there. The command fdisk -l shows mmcblk0p1 with the correct partitions of my micro SD card.
Any help is appreciated.
Andrew
