And it does make sense because the SDCARD organization says that you must pay royalties if you want to use the 4 bits mode
Until you realize the eMMC populated on the BeagleBone black doesn't
talk over SPI mode... Otherwise it too would be limited to 5Mb/s.
Obviously a driver problem..
I believe that the pattern of activity on pin 3 and 7 would be swapped when changing from read to write if you were right. The pattern of activity is the same, suggesting 1 bit SD access.
It’s working !!!
I took a wild guess, and decompiled /boot/am335x-boneblack.dtb
I found the parts for the three mmc controllers. I figured that mmc@48060000 was the uSD slot and mmc@481d8000 was the eMMC part. The second one had this line: bus-width = <0x8>;
What if we took this hint, and added bus-width = <0x4>; to the first one?. I compiled the dts file and rebooted.
Read speed: 19.9 MB/s
Write speed 8.8 MB/s
Yeah! I just tripled the performance of the uSD card.
This works both when booted from the eMMC and when booted from the uSD card.
This was done on Angstrom “Linux beaglebone 3.8.13 #1 SMP Wed Sep 4 09:09:32 CEST 2013 armv7l GNU/Linux”. Haven’t tested it on Debian yet.
I don’t know if this is the right way to do things or if it is just a dirty hack, and I don’t know who to notify of my findings. Please assist.
Jens,
Nice find ! Would you mind doing a mini writeup ? Not quite sure exactly what you’ve done, but I would be willing to test on my end too as well.
I found . . .
&mmc2 {
vmmc-supply = <&vmmcsd_fixed>;
bus-width = <8>;
ti,non-removable;
status = “okay”;
reset = <&rstctl 0 0>;
reset-names = “eMMC_RSTn-CONSUMER”;
but nothing else in ./arch/arm/boot/dts/am335x-boneblack.dts. Is this what I am looking for ?
Sure, no problem.
(Please make a backup first. This worked for me, there are no guarantees that it will work for you. I haven’t yet been able to confirm that this is the right way to solve the problem)
- decompile the device tree:
dtc -I dtb -O dts -o test.dts /boot/am335x-boneblack.dtb
- Edit the decompiled file:
nano test.dts
3.Search for the parts with the mmc controllers:
^w
mmc@48060000
- You will see three mmc controllers:
mmc@48060000 {
compatible = “ti,omap3-hsmmc”;
ti,hwmods = “mmc1”;
ti,dual-volt;
ti,needs-special-reset;
ti,needs-special-hs-handling;
dmas = <0x8 0x18 0x8 0x19>;
dma-names = “tx”, “rx”;
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <0x9>;
cd-gpios = <0xa 0x6 0x0>;
cd-inverted;
vmmc-supply = <0xb>;
ti,vcc-aux-disable-is-sleep;
linux,phandle = <0x28>;
phandle = <0x28>;
mmc@481d8000 {
ti,hwmods = “mmc2”;
dmas = <0x8 0x2 0x8 0x3>;
status = “disabled”;
bus-width = <0x8>;
ti,non-removable;
reset = <0xc 0x0 0x0>;
linux,phandle = <0x29>;
phandle = <0x29>;
mmc@47810000 {
ti,hwmods = “mmc3”;
linux,phandle = <0x2a>;
phandle = <0x2a>;
The first one is the uSD card (“mmc1”). The second one is the eMMC device and the third one is unused.
- Add this line to the first one:
bus-width = <0x4>;
I don’t know if the order of the lines is critical, but I added the line below the vmmc-supply line, just like the eMMC device.
The first device should now look like this:
mmc@48060000 { compatible = "ti,omap3-hsmmc"; ti,hwmods = "mmc1"; ti,dual-volt; ti,needs-special-reset; ti,needs-special-hs-handling; dmas = <0x8 0x18 0x8 0x19>; dma-names = "tx", "rx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x9>; cd-gpios = <0xa 0x6 0x0>; cd-inverted; vmmc-supply = <0xb>; bus-width = <0x4>; ti,vcc-aux-disable-is-sleep; linux,phandle = <0x28>; phandle = <0x28>; };
- Save the file
^x
y
[enter]
- compile the dts file:
dtc -I dts -O dtb -o /boot/am335x-boneblack.dtb test.dts
- reboot
reboot
- Enjoy
YMMV. I got about three times better performance with a Sandisk Ultra card. If you have a slower card, you will not see the same improvement.
oh, and the above writeup was done on Angstrom.
Awesome thanks Jens. Exact steps
Second post I just made was from a dts file I searched through using nano that came from instruction given by Robert Nelsons Linux on ARM ( debian 3.8.x ). Figured it was not right, but was about to search through a couple of includes . . .
Nice find..
/dev/mmcblk0:
Timing cached reads: 380 MB in 2.01 seconds = 189.30 MB/sec
Timing buffered disk reads: 56 MB in 3.00 seconds = 18.64 MB/sec
you can also just add the 4bit setting to the device dtb via:
diff --git a/arch/arm/boot/dts/am335x-bone.dts
b/arch/arm/boot/dts/am335x-bone.dts
index d5f43fe..aa1efb1 100644
--- a/arch/arm/boot/dts/am335x-bone.dts
+++ b/arch/arm/boot/dts/am335x-bone.dts
@@ -19,4 +19,5 @@
&mmc1 {
status = "okay";
vmmc-supply = <&ldo3_reg>;
+ bus-width = <0x4>;
diff --git a/arch/arm/boot/dts/am335x-boneblack.dts
b/arch/arm/boot/dts/am335x-boneblack.dts
index a6d7b0e..2a3f731 100644
--- a/arch/arm/boot/dts/am335x-boneblack.dts
+++ b/arch/arm/boot/dts/am335x-boneblack.dts
@@ -22,6 +22,7 @@
&mmc1 {
&mmc2 {
Confirmed here too . .
william@arm:~$ lsb_release -a | grep Description
No LSB modules are available.
Description: Debian GNU/Linux 7.1 (wheezy)
william@arm:~$ uname -a
Linux arm 3.8.13-bone21 #1 SMP Sat Jun 15 19:36:33 MST 2013 armv7l GNU/Linux
william@arm:~$ sudo hdparm -tT /dev/mmcblk1
/dev/mmcblk1:
Timing cached reads: 456 MB in 2.00 seconds = 227.80 MB/sec
Timing buffered disk reads: 54 MB in 3.07 seconds = 17.56 MB/sec
However I did this slightly differently.
first I made a backup of the dtb on the beaglebone ( cp’d to ~/ on a reg user ) then on my cross system…
william@support:~$ nano ~/debian/linux-dev/KERNEL/arch/arm/boot/dts/am335x-boneblack.dts
^W added bus-width and found . . .
&mmc1 {
bus-width = <0x4>; //<— added this
saved out of nano.
william@support:~/debian/linux-dev/KERNEL$ dtc -I dts -O dtb -o ~/am335x-boneblack.dtb ./arch/arm/boot/dts/am335x-boneblack.dts
And I boot tftp / nfs on my BBB from this cross system, so all i had to do was move the file into the nfsroot/boot, and bam done.
Thanks again jens awesome find.
If you wants something added to the kernel, send a pull request against https://github.com/beagleboard/kernel/
For people wanting to get this speed boost, just do:
opkg update ; opkg install kernel-devicetrees ; reboot
That will install the new devicetree(s) and nothing else and reboot into the new, much faster system.
regards,
Koen
Thank you Koen. As far as I can tell, you did the pull request already, so no need for me to do it now, right? (sorry if it’s a total noob question)
And thanks to those of you brave enough to confirm my finding.
Thank you Koen. As far as I can tell, you did the pull request already, so no need for me to do it now, right? (sorry if it's a total noob question)
Right ![]()
And for future reference, you can inspect the mmc parameters using debugfs as well:
root@beaglebone-cam:~# cat /sys/kernel/debug/mmc1/ios
clock: 52000000 Hz
vdd: 7 (1.65 - 1.95 V)
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 2 (on)
bus width: 3 (8 bits)
timing spec: 1 (mmc high-speed)
signal voltage: 0 (3.30 V)
root@beaglebone-cam:~# cat /sys/kernel/debug/mmc0/ios
clock: 50000000 Hz
vdd: 20 (3.2 ~ 3.3 V)
power mode: 2 (on)
bus width: 2 (4 bits)
timing spec: 2 (sd high-speed)
I wonder if am335x can support the 100 and 200MHz modes in the UHS-I spec, that would be a neat speed boost.
regards,
Koen
That debugfs command could have saved me from a huge learning experience
According to the Technical Reference Manual for the MPU, 24 MB/s is the theoretical maximum speed for a 4-bit connection.
D’oh ! Silly me, I was editing the wrong file, or rather I was putting it into the wrong place. tftp gotcha !
william@arm:~$ sudo hdparm -tT /dev/mmcblk0
/dev/mmcblk0:
Timing cached reads: 482 MB in 2.00 seconds = 240.72 MB/sec
Timing buffered disk reads: 54 MB in 3.05 seconds = 17.68 MB/sec
/dev/mmcblk1:
Timing cached reads: 402 MB in 2.00 seconds = 200.65 MB/sec
Timing buffered disk reads: 54 MB in 3.08 seconds = 17.56 MB/sec
Got it right now though ! mmcblk0 is the sdcard.
What would the equivalent package for Debian? There doesn’t seem to be any Debian package called “kernel-devicetrees”.
It's built into the linux-image-(uname -r) package..
