Hi group,
I got the Cable Unlimited's usb to serial convert for my mac book that
runs os x (10.5).
Driver was installed smoothly.
After connecting with the beagle board, the minicom on my mac got the
booting msg from beagle just fine, but after the command prompt "#", I
can't type in anything to command the beagle board.
Hit "Ctrl - A", minicom shows "offline".
Can't figure out, anybody?
Thanks in advance.
Roger
Make sure you have the correct IDC to DB9 cable plugged in correctly and the null modem cable. Refer to the latest System Reference Manual Rev B5 section 13.3 http://www.beagleboard.org/uploads/BBSRM_B5.pdf and the FAQs at http://beagleboard.org/support/faq.
The cable is no good…
Please see the following for the correct wiring:
http://www.pccables.com/07120.htm
This is NOT what ANY of the cables in my junk drawer look like…
Howdy all,
I am plodding through the steps of building Angstrom for the Beagleboard.
I can ‘bitbake nano’ but ‘bitbake base-image’ goes off building all of the X Window System.
Any idea where this is added in? All I want the the kernel and userland.
Thanks!
Known-good cables and other accessories for the BeagleBoard can be ordered here:
https://specialcomp.com/beagleboard/order.htm
Bill Mar
Special Computing
Howdy all,
I can 'bitbake nano' but 'bitbake base-image' goes off building all of the X
Window System.
Try "bitbake console-image"
Philip
Howdy all,
Window System.
Some packages (e.g. bluez, dbus or python and its tk module) have
subpackages that require X to build. That X11 stuff is being built has
no bearing on what will end up in your image. If you unpack a base-
image tarball you'll find no X stuff in there.
regards,
Koen
The issue seems to be a bit uglier than that.
I had tried 'bitbake beagleboard-demo-image' but it failed building
'gstreamer'.
That failed package seems to have persisted in the 'system' directory.
'gstreamer' keeps popping up until I remove the 'system' directory and start
all over...
Best regards,
- dan
