Thank you for the tips.
I installed the windows XP driver http://www.davehylands.com/linux/gumstix/usbnet/linux.inf
per the gumstix how to.
I loaded the g_ether and related modules from
http://www.angstrom-distribution.org/demo/beagleboard/modules-2.6.29-r37-beagleboard.tgz
(btw: this fixed my ipv6 struct mismatch)
The following is a dump of my current progress.
Please shove me in the right direction again.
Thank you and respectfully,
d1m_bu1b
I was not able to run insmod, modinfo... on g_ether like you can with
other modules
So I supplied the entire pathname:
root@beagleboard:~# insmod /lib/modules/2.6.29-omap1/kernel/drivers/
usb/gadget/g_ether.ko
and got:
[ 414.217651] g_ether gadget: using random self ethernet address
[ 414.223602] g_ether gadget: using random host ethernet address
[ 414.230255] usb0: MAC 66:3e:f5:5e:49:db
[ 414.234191] usb0: HOST MAC ba:50:b0:bf:2b:2c
[ 414.238525] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 414.245239] g_ether gadget: g_ether ready
[ 414.249298] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 414.255065] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number
2
[ 414.262969] usb usb2: configuration #1 chosen from 1 choice
[ 414.268798] hub 2-0:1.0: USB hub found
[ 414.273590] hub 2-0:1.0: 1 port detected
[ 414.338470] ADDRCONF(NETDEV_UP): usb0: link is not ready
I went into the Angstrom(enlightenment?) network tool and set usb0 and
usbd0 to dhcp.
root@beagleboard:~# ifconfig -a
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:600 (600.0 b) TX bytes:600 (600.0 b)
usb0 Link encap:Ethernet HWaddr 66:3E:F5:5E:49:DB
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
root@beagleboard:~# modinfo /lib/modules/2.6.29-omap1/kernel/drivers/
filename: /lib/modules/2.6.29-omap1/kernel/drivers/usb/gadget/
g_ether.ko
license: GPL
author: David Brownell, Benedikt Spanger
description: RNDIS/Ethernet Gadget
srcversion: B9A1781473E6AA9D4592E2D
depends:
vermagic: 2.6.29-omap1 mod_unload modversions ARMv7
parm: idVendor:USB Vendor ID (ushort)
parm: idProduct:USB Product ID (ushort)
parm: bcdDevice:USB Device version (BCD) (ushort)
parm: iManufacturer:USB Manufacturer string (charp)
parm: iProduct:USB Product string (charp)
parm: iSerialNumber:SerialNumber string (charp)
parm: qmult:queue length multiplier at high speed (uint)
parm: dev_addr:Device Ethernet Address (charp)
parm: host_addr:Host Ethernet Address (charp)
then I plugged the mini-B from my PC into the OTG port, and got:
[ 127.490631] Kernel panic - not syncing: Fatal exception in
interrupt
root@beagleboard:~# [ 125.965850] g_ether gadget: high speed config
#2: RNDIS
[ 125.972778] ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 126.852111] Unable to handle kernel NULL pointer dereference at
virtual addre
ss 00000000
[ 126.860290] pgd = cbaa4000
[ 126.863006] [00000000] *pgd=8bb01031, *pte=00000000, *ppte=00000000
[ 126.869323] Internal error: Oops: 17 [#1]
[ 126.873352] Modules linked in: g_ether omaplfb pvrsrvkm ircomm_tty
ircomm ird
a ipv6
[ 126.881134] CPU: 0 Not tainted (2.6.29-omap1 #1)
[ 126.886138] PC is at strlen+0x18/0x2c
[ 126.889892] LR is at rndis_msg_parser+0x3a0/0x7ac [g_ether]
[ 126.895507] pc : [<c01d0a08>] lr : [<bf0e87fc>] psr: 60000193
[ 126.895507] sp : cf087bc0 ip : cf087bd0 fp : cf087bcc
[ 126.907043] r10: cf23d320 r9 : d80ab000 r8 : cf23d334
[ 126.912292] r7 : cf23d34c r6 : cf23d334 r5 : bf0ecdf4 r4 :
00000000
[ 126.918853] r3 : bf0ecdf4 r2 : 00000000 r1 : bf0ece24 r0 :
00000000
[ 126.925445] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM
Segment use
r
[ 126.932708] Control: 10c5387d Table: 8baa4019 DAC: 00000015
[ 126.938476] Process OGLESChameleonM (pid: 1927, stack limit =
0xcf0862e8)
[ 126.945312] Stack: (0xcf087bc0 to 0xcf088000)
[ 126.949676] 7bc0: cf087bf4 cf087bd0 bf0e87fc c01d09fc cf31afa0
ce218260 00000
000 00000000
[ 126.958068] 7be0: d80ab100 d80ab100 cf087c1c cf087bf8 bf0e8c34
bf0e8468 bf0e9
794 bf0e7dc8
[ 126.966461] 7c00: 00000052 ce218260 cf98c1b4 00000000 cf087c4c
cf087c20 c02f0
374 bf0e8c14
[ 126.974853] 7c20: c02f0374 00000000 00000008 cf98c0f0 00000c78
ce218278 cf98c
0f0 ce218260
[ 126.983215] 7c40: cf087ca4 cf087c50 c02ef884 c02f0298 c02f1600
c02f0298 2e93b
90a 00000052
[ 126.991607] 7c60: 2e93b90a cf98c188 cf98c32c 0021c368 00000000
cfac004c 00000
008 40000113
[ 127.000000] 7c80: 00000000 cf98c0f0 00000000 00000000 00000099
00000000 cf087
cec cf087ca8
[ 127.008361] 7ca0: c02ee5a0 c02ef5fc c02f5cc4 c02edb38 c00755b0
cf087cc0 c05bb
808 000000f0
[ 127.016754] 7cc0: cf087cc0 40000113 00000000 00000000 0000005c
bef75a54 cf086
000 00000000
[ 127.025146] 7ce0: cf087d04 cf087cf0 c02eea7c c02eddfc cf086000
cfacc580 cf087
d24 cf087d08
[ 127.033538] 7d00: c00883ac c02eea24 c0585d1c 0000005c bef75a54
cf13cd60 cf087
d3c cf087d28
[ 127.041900] 7d20: c0089830 c008837c 0000005c 00000000 cf087d54
cf087d40 c003a
058 c00897a8
[ 127.050292] 7d40: ffffffff d8200000 cf087db4 cf087d58 c003aa30
c003a00c 00002
53e 0000005c
[ 127.058685] 7d60: 00000760 0007a11f cf13cd60 c01c674f bef75a54
cf13cd60 bef75
a54 cf086000
[ 127.067047] 7d80: 00000000 cf087db4 cf087db8 cf087da0 bf0ad3a0
c01c9f80 20000
013 ffffffff
[ 127.075439] 7da0: f30db790 00000032 cf087dfc cf087db8 bf0b42c8
bf0ad390 00000
000 00000000
[ 127.083831] 7dc0: 00000000 00000001 cb47ee20 d0b46000 cf090ed0
00000001 f30d9
90c 00000050
[ 127.092193] 7de0: cb47ee20 d0d4f090 cb47ee20 d0d4f090 cf087e34
cf087e00 bf0bc
3f0 bf0b41c8
[ 127.100585] 7e00: fff75a8f 00000000 cf1f18c0 cf2bb000 cf2ba000
0000004f bef75
a80 cb47ee20
[ 127.108978] 7e20: cf23d9e0 d0b46000 cf087e84 cf087e38 bf0c011c
bf0bc2f8 00000
010 bf0af0c8
[ 127.117340] 7e40: 00000000 00000000 00000001 00000000 cf087eb0
cf1f18c0 cf3ce
6a0 bf0d85bc
[ 127.125732] 7e60: cf2ba000 cf2bb000 bf0bc2ec 0000004f fffffff2
cf087e5c cf087
eec cf087e88
[ 127.134124] 7e80: bf0b06ac bf0bfe64 00000000 00000001 ffffffff
cf3452c0 bef75
a54 c01c674f
[ 127.142486] 7ea0: cf13cd60 cf0ab610 cf2619c0 cf1f18c0 0000004f
0000001c bef75
a80 00000010
[ 127.150878] 7ec0: bef75a90 00000008 00000001 0000004f bef75a54
00000787 fffff
ff2 00000000
[ 127.159271] 7ee0: cf087f0c cf087ef0 c00c7198 bf0b0500 c0054378
00000005 cf13c
d60 c01c674f
[ 127.167663] 7f00: cf087f7c cf087f10 c00c7678 c00c7138 00000000
00000000 fffff
ffd 00000000
[ 127.176025] 7f20: cf087f54 cf087f30 c0075d94 c004f464 cf26e01c
cf2619c0 00000
015 cfad0e00
[ 127.184417] 7f40: 88db592d c05b5e70 cf087f6c cf087f58 c0075e7c
00000005 bef75
a54 c01c674f
[ 127.192810] 7f60: cf13cd60 c003b004 cf086000 00000000 cf087fa4
cf087f80 c00c7
71c c00c71e0
[ 127.201171] 7f80: c0062cc0 00000000 00000000 00000001 00185f80
00000036 00000
000 cf087fa8
[ 127.209564] 7fa0: c003ae80 c00c76e8 00000000 00000001 00000005
c01c674f bef75
a54 0000001c
[ 127.217956] 7fc0: 00000000 00000001 00185f80 00000036 405782b4
00000000 00000
000 00000000
[ 127.226318] 7fe0: 00000001 bef75a50 404196c8 4039b81c 20000010
00000005 80809
021 80809421
[ 127.234710] Backtrace:
[ 127.237182] [<c01d09f0>] (strlen+0x0/0x2c) from [<bf0e87fc>]
(rndis_msg_parse
r+0x3a0/0x7ac [g_ether])
[ 127.246520] [<bf0e845c>] (rndis_msg_parser+0x0/0x7ac [g_ether])
from [<bf0e8c
34>] (rndis_command_complete+0x2c/0x74 [g_ether])
[ 127.258056] [<bf0e8c08>] (rndis_command_complete+0x0/0x74
[g_ether]) from [<c
02f0374>] (musb_g_giveback+0xe8/0x10c)
[ 127.268615] r6:00000000 r5:cf98c1b4 r4:ce218260
[ 127.273284] [<c02f028c>] (musb_g_giveback+0x0/0x10c) from
[<c02ef884>] (musb_
g_ep0_irq+0x294/0xa5c)
[ 127.282409] r7:ce218260 r6:cf98c0f0 r5:ce218278 r4:00000c78
[ 127.288116] [<c02ef5f0>] (musb_g_ep0_irq+0x0/0xa5c) from
[<c02ee5a0>] (musb_i
nterrupt+0x7b0/0xc28)
[ 127.297180] [<c02eddf0>] (musb_interrupt+0x0/0xc28) from
[<c02eea7c>] (generi
c_interrupt+0x64/0x7c)
[ 127.306304] [<c02eea18>] (generic_interrupt+0x0/0x7c) from
[<c00883ac>] (hand
le_IRQ_event+0x3c/0x74)
[ 127.315551] r4:cfacc580
[ 127.318115] [<c0088370>] (handle_IRQ_event+0x0/0x74) from
[<c0089830>] (handl
e_level_irq+0x94/0xec)
[ 127.327239] r7:cf13cd60 r6:bef75a54 r5:0000005c r4:c0585d1c
[ 127.332977] [<c008979c>] (handle_level_irq+0x0/0xec) from
[<c003a058>] (__exc
eption_text_start+0x58/0x70)
[ 127.342620] r5:00000000 r4:0000005c
[ 127.346252] [<c003a000>] (__exception_text_start+0x0/0x70) from
[<c003aa30>]
(__irq_svc+0x30/0x80)
[ 127.355285] Exception stack(0xcf087d58 to 0xcf087da0)
[ 127.360351]
7d40: 00002
53e 0000005c
[ 127.368743] 7d60: 00000760 0007a11f cf13cd60 c01c674f bef75a54
cf13cd60 bef75
a54 cf086000
[ 127.377136] 7d80: 00000000 cf087db4 cf087db8 cf087da0 bf0ad3a0
c01c9f80 20000
013 ffffffff
[ 127.385498] r5:d8200000 r4:ffffffff
[ 127.389129] [<bf0ad384>] (OSWaitus+0x0/0x24 [pvrsrvkm]) from
[<bf0b42c8>] (SG
X2DQueryBlitsCompleteKM+0x10c/0x288 [pvrsrvkm])
[ 127.400756] [<bf0b41bc>] (SGX2DQueryBlitsCompleteKM+0x0/0x288
[pvrsrvkm]) fro
m [<bf0bc3f0>] (SGX2DQueryBlitsCompleteBW+0x104/0x12c [pvrsrvkm])
[ 127.413879] [<bf0bc2ec>] (SGX2DQueryBlitsCompleteBW+0x0/0x12c
[pvrsrvkm]) fro
m [<bf0c011c>] (BridgedDispatchKM+0x2c4/0x360 [pvrsrvkm])
[ 127.426361] [<bf0bfe58>] (BridgedDispatchKM+0x0/0x360 [pvrsrvkm])
from [<bf0b
06ac>] (PVRSRV_BridgeDispatchKM+0x1b8/0x1f8 [pvrsrvkm])
[ 127.438598] [<bf0b04f4>] (PVRSRV_BridgeDispatchKM+0x0/0x1f8
[pvrsrvkm]) from
[<c00c7198>] (vfs_ioctl+0x6c/0x7c)
[ 127.448913] [<c00c712c>] (vfs_ioctl+0x0/0x7c) from [<c00c7678>]
(do_vfs_ioctl
+0x4a4/0x508)
[ 127.457244] r6:c01c674f r5:cf13cd60 r4:00000005
[ 127.461914] [<c00c71d4>] (do_vfs_ioctl+0x0/0x508) from [<c00c771c>]
(sys_ioct
l+0x40/0x64)
[ 127.470184] [<c00c76dc>] (sys_ioctl+0x0/0x64) from [<c003ae80>]
(ret_fast_sys
call+0x0/0x2c)
[ 127.478607] r7:00000036 r6:00185f80 r5:00000001 r4:00000000
[ 127.484344] Code: e24cb004 e1a02000 ea000000 e2800001 (e5d03000)
interrupt
this also locked up my pc until I unpluged the USB cable
