Kazz
July 20, 2015, 11:45am
1
Hi all.
I am using the Beagleboard-xM and Beaglebone Black.
I installed the debian-8.1-console-armhf-2015-06-11 both them.
And I installed the mjpg-streamer-r63, which was compiled from the same source code for both.
I connect the same Logicool Webcam C-615 both, They was executed the following start-up script.
mjpg_streamer -i “input_uvc.so -d / dev / video0 -f 2 -r 640x480” -o “output_http.so -p 8081 -w / home / www” -b
As a result, Beaglebone Black works well in MJPEG format,but Beagleboard-xM in a small white square appears.
Both, in the YUV format, works well.
Why is there is such a difference?
Kazz
July 21, 2015, 9:59pm
2
The difference between both.
Result “ldd input_uvc.so”
Beagleboard
linux-vdso.so.1 (0xbec04000)
libjpeg.so.62 => /usr/lib/arm-linux-gnueabihf/libjpeg.so.62 (0xb6f7f000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e90000)
/lib/ld-linux-armhf.so.3 (0x7f60d000)
BeagleboneBlack
libjpeg.so.62 => /usr/lib/arm-linux-gnueabihf/libjpeg.so.62 (0xb6f6a000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e7c000)
/lib/ld-linux-armhf.so.3 (0xb6fc8000)
What’s linux-vdso.so1 ?
Unrelated ?
Kazz
July 21, 2015, 10:20pm
3
Rasult “v4l2-ctl -all”
Beagleboard-xm
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : HD Webcam C615
Bus info : usb-48064800.ehci-2.2
Driver version: 4.1.0
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : ‘YUYV’
Field : None
Bytes per Line: 1280
Size Image : 614400
Colorspace : SRGB
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 640, Height 480
Default : Left 0, Top 0, Width 640, Height 480
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 640, Height 480
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 480
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
BeagleboneBlack
Bus info : usb-musb-hdrc.1.auto-1.1
Driver version: 3.14.43
Capabilities : 0x84000001
Video Capture
Streaming
Device Capabilities
Device Caps : 0x04000001
Video Capture
Streaming
Priority: 2
Field : None
Size Image : 614400
Colorspace : SRGB
Pixel Aspect: 1/1
Read buffers : 0
Defference of Driver version is perhaps kernel version.
