mjpg streamer problem
Anyone else faced up with a problem like this one?
I’m using a BBB rev C with Debian, image 3.8.13-bone70, with a Microsoft® LifeCam HD-3000 directly connected to BBB USB port and streaming to my LAN via ethernet cable.
this is the result of v4l2-ctl
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : Microsoft® LifeCam HD-3000
Bus info : usb-musb-hdrc.1.auto-1
Driver version: 3.8.13
Capabilities : 0x84000001
Video Capture
Streaming
Format Video Capture:
Width/Height : 1280/720
Pixel Format : ‘MJPG’
Field : None
Bytes per Line: 0
Size Image : 1843200
Colorspace : SRGB
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1280, Height 720
Default : Left 0, Top 0, Width 1280, Height 720
Pixel Aspect: 1/1
Video input : 0 (Camera 1: ok)
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 7.500 (15/2)
Read buffers : 0
Priority: 2
Launching mjpg_streamer with this command:
/usr/local/bin/mjpg_streamer -i “/usr/local/lib/input_uvc.so -n -f 5 -r 1280x720” -o “/usr/local/lib/output_http.so -w /usr/local/www”
it starts fine with a regular output:
MJPG Streamer Version: svn rev:
i: Using V4L2 device.: /dev/video0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 5
i: Format…: MJPEG
o: www-folder-path…: /usr/local/www/
o: HTTP TCP port…: 8080
but very frequently it stops with this error:
*** glibc detected *** /usr/local/bin/mjpg_streamer: double free or corruption (fasttop): 0x00015690 ***
Aborted
any idea?
thank you in advance.
A little update.
Connecting to the video stream with Chrome (OS X 10.10.2), it’s stable since more than 24 hours. Connecting via Safari, mjpg_streamer crashes randomly after some minutes or some hours.
I’m using the mjpg_streamer version already installed in image 3.8.13-bone70.
Could I try compiling it with different switches and upgrading all the dependencies?
