In case it's useful for anyone else, I have ported code for the
MLX90621 (4x16 pixel remote IR temperature sensor) from the RPi (talks
directly to the BCM hardware) to use standard Linux I2C devices (eg:
/dev/i2c1) so it works on the 'Bone and other boards with standard
Linux I2C support.
Tested on a BBB using I2C2 (/dev/i2c1, the cape EEPROM I2C bus), 5.6K
pull-up resistors, and a diode-connected transistor to drop the 3.3V
rail to the 2.6V preferred by the MLX.
Thanks for that. I’ve done something similar for another Melexis device, the MLX90640 32x24 sensor.
However, I’ve used a rather bizarre interface : an arduino that does the I2C operations remotely via the usual USB-serial interface.
It also handles a couple of ST vl53l1x distance sensors. This is because I wanted a fairly generic connection that wasn’t tied to the capabilities of any particular SBC.
It’s a fairly slow way to do things and suffers from the small buffer memory in the arduino, but the USB-serial part is fairly well encapsulated and I can probably learn something from your use of the direct i2c connection. Or perhaps use USB natively, without the serial part, on a different microcontroller such as a teensy or maple.
