Mouse/Keyboard not working
Mouse is not working with the latest binaries, which I downloaded from
http://labs.embinux.org/index.php/Android_Porting_Guide_to_Beagle_Board
However mouse works with the binaries which I downloaded few months
back.
1.I am using USB hub for connecting Keyboard and mouse
2.Board is powered with 5V, 4A Power supply. Is ampare rating
correct???
3.I set the bootargs properly.
4.log prints the properties of the mouse and keboard, as soon as plug
them into the hub.
Any help from anybody would be highly appreciated!!
Sanjeev Kumar Verma
Voce tem que ver qual versão da BB que esta usando se é C3 igual a minha mas não consigo colocar internet nela ou se é B5 que é facil ou entre outra, olha qual é a sua pega o manual de hardware para ver onde tem que dar um pingo de solda na mini-usb para torna PRI-MASTER.. ai ira funcionar....
Sanjeev,
  Are you using uboot binary provided with other binaries ? Probably you
need to use right uboot version.
Rupesh,
Actually, initially this message comes: The battery is getting low and
less than 15% remaining and the system hangs.
I think since it hangs that's why the keyboard and mouse are not
working. Through one of the discussion forum (http://groups.google.com/
group/android-porting/browse_thread/thread/f2a274e17a4c0230 ) I got
the way to remove this message by modifying one of the cpp file , but
still the mouse movements are reflecting in the display. However if I
press CTL+ALT+DEL the board restarts.
I tried to download the android build and buit it and the kernel
(uImage)as well and then created the SD Card with this. Here also it
hangs after boot. I am only using the uImage in my first partition, I
could not find other binaries (MLO and u-boot.bin), Can you tell me
which directory of kernel source will have them? )were.However,
earlier I tried using All the three binaries MLO, u-boot.bin and
uImage, result was same by pressing the user button and booting.
Am I suppose to use all the three binaries or the uImage is sufficient
in the first partition??
What version of kernel/binaries should I use? Can you please point me,
where to get them from?
Which is the latest version with stable Android and stable kernel?
Sanjeev,
Sanjeev Kumar Verma wrote:
Rupesh,
You can very well ignore this error message at boot time, System do not hang at this point.
If your keyboard is working you can press on “OK” to get out of it.
You can download prebuild binaries from following link. This tar ball also contains MLO and uboot binaries.
Note :- 1. is absolute and we had moved to new page ie. (). Future support will be available for this build. 2. Prebuild binaries are from older build, and do not contain Gstreamer integration. Regards,
Hi Rupesh,
I need the source for U-boot and X-loader for the android on beagle
board.
I have attended your presentation at Bangalore last week.
As you said if u-boot is from different binaries how come the key
board will not work.
can you explain me?
I want the key board and mouse work properly for the beagle board.
Thanx
Phaneendra
