Mouse not detected in BeagleBoard Xm rev C running Angstrom + getting junk characters in minicom
I built my Angstrom image using http://narcissus.angstrom-distribution.org/ and followed instructions from http://treyweaver.blogspot.com/2010/10/installing-angstrom-on-beagleboard-xm.html . Now when I boot my board, everything works but the mouse is not detected. I even tried using a self powered hub, but even that does not work.
When I write, ‘lsusb’ via the serial console , it gives me some valid output. So, despite the USB ports being detected, the mouse does not work.
So can anyone please help me out here?
This is the output I get on minicom when the board boots up:
Te�as Instruments X-Lader 1.5.0 (Jun 14 2011 - 22:04:07)
Beagle �M
U����� boot sectr
Lading u-boot.bin frm mmc
U-Bot 2011.03-rc1-00000-g9a3cc57-dirt~B
�� 01 2011 - 17:41:42)
_MAP36XX?37XX-GP ES2.1, CPU-OPP2, L3-165MH? j���CPU Clck 1 Gh
_MAP3 Beagle board + LPDDR?NAND
I2C: ���
DRAM: 512 MiB
*9: 0 MiB
MMC: _MAP SD/MMC: 0
*** Warning - readenv() failed, using default envirnment
In: serial
_ut: serial
Err: serial
Beagle �M Rev C
No EEPR_M n expansin board
Die ID #1ada00029ff80000016842c812007018
Hit an� ke~�� stp autbot: 0
The user buttn is currentl~r}Q pressed.
SD/MMC found on device 0
rNV���� uEnv.t�t
** Unable to read “uEnv.t�t” frm mmc 0:1 **
Lading file “?boot?uImage” from mmc device 0:2 (��a2)
3203088 b�tes read
�륹� frm mmc …
Booting kernel frm Legac~J���� at 80200000 …
Image Name: Angstrom/2.6.32?beagleboard
Image T~�: ARM Linu� Kernel Image (uncompressed)
Data Sie: 3203024 B�tes } 3.1 MiB
Lad Address: 80008000
Entr~Pint: 80008000
Verif�ing Checksum … OK
Lading Kernel Image … OK
_K
Starting kernel …
Uncompressing Linu�…��…�…�…�…��…�…�…���…�…�…�…�…�…�…�…�.�…�…�.��.
+�r������] Linu version 2.6.32 (ken@dminin) (gcc versin 4.3.3 (GCC) ) #3 PREEMPT Tue Jul 26 10:56:56 CEST 2011
[ 0.000000] CPU: ARMv7 Prcessr [413fc082] revisin 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: _MAP3 Beagle Bard
[ 0.000000] Memr~������: ECC disabled, Data cache �riteback
[ 0.000000] MAP3630?DM3730 ES1.0 (l2cache iva sg� nen isp 192mh�5�� )
[ 0.000000] SRAM: Mapped pa 0�40200000 t va 0�fe400000 sie: 0100000
[ 0.000000] Reserving 12582912 b�tes SDRAM for VRAM
[ 0.000000] Built 1 �˕����� in Zone rder, mobilit~:������� n. Ttal pages: 130048
[ 0.000000] Kernel command line: consle}tt~&)�����r8 mpurate}aut budd~_�� camera}lbcm3m1 vram}12M mapfb.mde}dvi:640�480MR-16@60 mapdss.def_di5
e
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 2048 (rder: 1, 8192 b�tes)
[ 0.000000] Dentr~���� hash table entries: 65536 (rder: 6, 262144 b�tes)
[ 0.000000] Inode-cache hash table entries: 32768 (rder: 5, 131072 b�tes)
[ 0.000000] Memor~'���j 256MB } 512MB ttal
[ 0.000000] Memr~'������Z available (5900K code, 673K data, 204K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clcking rate (Cr~.W�?Cre/MPU): 26.0?332?600 MH
[ 0.000000] Reprgramming SDRC clck t 332000000 H
[ 0.000000] GPMC revisin 5.0
[ 0.000000] IRQ: Found an INTC at 0�fa200000 (revisin 4.0) �ith 96 interrupts
[ 0.000000] Ttal of 96 interrupts n 1 active contrller
[ 0.000000] MAP GPI hardware versin 2.5
[ 0.000000] _MAP clckevent source: GPTIMER12 at 32768 H
[ 0.000000] Cnsole: colur dumm� device 80�30
[ 0.000000] Calibrating dela� lp… 507.32 BgoMIPS (lpj=1982464)
[ 0.000000] Munt-cache hash table entries: 512
[ 0.000000] CPU: Testing �rite buffer coherenc~'k
[ 0.000000] tmpfs: N value for mount ption ‘mode’
[ 0.000000] devtmpfs: initialied
[ 0.000000] regulatr: core versin 0.5
[ 0.000000] NET: Registered prtcol famil~��j
[ 0.000000] MAP3 Beagle Rev: �M C
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND n CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable t get DVI reset GPI
[ 0.000000] map_init_mbo�: platform not supported
[ 8.954925] _MAP DMA hardware revisin 5.0
[ 8.961242] bio: create slab at 0
[ 8.962463] SCSI subs�stem initialied
[ 8.963775] usbcore: registered ne� interface driver usbfs
[ 8.963897] usbcore: registered neJ�ѕə��� driver hub
[ 8.964080] usbcore: registered ne"�٥�� driver usb
[ 8.964477] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kH
[ 8.967132] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 8.967163] twl4030: po�er (irq 373) chaining IRQs 376…383
[ 8.967437] twl4030: gpi (irq 368) chaining IRQs 384…401
[ 8.969116] regulatr: VUSB1V5: 1500 mV normal standb
[ 8.969329] regulatr: VUSB1V8: 1800 mV normal standb
[ 8.969543] regulatr: VUSB3V1: 3100 mV normal standb
[ 8.970825] twl4030_usb twl4030_usb: Initialied TWL4030 USB module
[ 8.971221] regulatr: VMMC1: 1850 ↔ 3150 mV normal standb
[ 8.971466] regulatr: VDAC: 1800 mV normal standb
[ 8.971679] regulatr: VPLL2: 1800 mV normal standb
[ 8.971923] regulatr: VSIM: 1800 |–> 3000 mV normal standb
[ 8.972229] regulatr: VAUX3: 1800 mV normal standb
[ 8.972595] regulatr: VAUX4: 1800 mV normal standb
[ 8.972747] i2c_omap i2c_map.2: bus 2 rev4.0 at 400 kH
[ 8.983978] i2c_map i2c_omap.3: bus 3 rev4.0 at 100 kH
[ 8.985168] S_э���� t clcksurce 32k_counter
[ 8.994262] musb_hdrc: version 6.0, musb-dma, tg (peripheral+host), debug}0
[ 8.997955] musb_hdrc: USB _TG mode contrller at fa0ab000 using DMA, IRQ 92
[ 8.997985] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 8.998107] musb_hdrc musb_hdrc: ne� USB bus registered, assigned bus number 1
[ 8.998229] usb usb1: New USB device found, idVendr=1d6b, idPrduct=0002
[ 8.998260] usb usb1: New USB device strings: Mfr=3, Prduct=2, SerialNumber=1
[ 8.998260] usb usb1: Prduct: MUSB HDRC host driver
[ 8.998291] usb usb1: Manufacturer: Linu 2.6.32 musb-hcd
[ 8.998291] usb usb1: SerialNumber: musb_hdrc
[ 8.998931] hub 1-0:1.0: USB hub found
[ 8.998962] hub 1-0:1.0: 1 port detected
[ 9.000000] NET: Registered prtcol famil~�j
[ 9.000183] IP rute cache hash table entries: 4096 (rder: 2, 16384 b�tes)
[ 9.000732] TCP established hash table entries: 16384 (rder: 5, 131072 b�tes)
[ 9.001190] TCP bind hash table entries: 16384 (rder: 4, 65536 b�tes)
[ 9.001403] TCP: Hash tables configured (established 16384 bind 16384)
[ 9.001434] TCP reno registered
[ 9.001434] UDP hash table entries: 256 (rder: 0, 4096 b�tes)
[ 9.001464] UDP-Lite hash table entries: 256 (rder: 0, 4096 b�tes)
[ 9.001708] NET: Registered prtcol famil~�j
[ 9.002136] RPC: Registered udp transport module.
[ 9.002166] RPC: Registered tcp transport module.
[ 9.002166] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 9.003021] map-immu omap-immu.0: isp registered
[ 9.004699] VFS: Disk quotas dquot_6.5.2
[ 9.004821] Dquot-cache hash table entries: 1024 (rder 0, 4096 b�tes)
[ 9.005859] squashfs: version 4.0 (2009?01?31) Phillip Lugher
[ 9.006652] JFFS2 versin 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 9.007446] msgmni has been set t 977
[ 9.011230] alg: No test for stdrng (krng)
[ 9.011505] Blck la�er SCSI generic (bsg) driver versin 0.4 laded (major 254)
[ 9.011535] io scheduler noop registered
[ 9.011535] io scheduler deadline registered
[ 9.011688] io scheduler cfq registered (default)
[ 9.071380] MAP DSS rev 2.0
[ 9.071441] OMAP DISPC rev 3.0
[ 9.071502] OMAP VENC rev 2
[ 9.071716] MAP DSI rev 1.0
[ 9.408325] Serial: 8250?16550 driver, 4 ports, IRQ sharing enabled
[ 9.426422] serial8250.0: tt~*
� MMI
0x4806a000 (irq } 72) is a ST16654
[ 9.443908] serial8250.1: tt~
� MMI
0�4806c000 (irq } 73) is a ST16654
[ 9.461395] serial8250.2: tt~
� MMI
049020000 (irq } 74) is a ST16654
[ 10.027648] consle [tt~*] enabled
[ 10.037841] brd: module laded
[ 10.044128] lp: module laded
[ 10.048736] omap2-nand driver initialiing
[ 10.053100] No NAND device found!!!
[ 10.056793] No NAND device found!!!
[ 10.061309] usbcore: registered ne� interface driver catc
[ 10.066802] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
+��r���¢�] usbcore: registered ne� interface driver ka�eth
[ 10.078460] pegasus: v0.6.14 (2006?09?27), Pegasus/Pegasus II USB Ethernet driver
+��r�²�ʂ] usbcore: registered neJ�ѕə��� driver pegasus
[ 10.091827] rtl8150: v0.6.2 (2004?08?27):rtl8150 based usb-ethernet driver
[ 10.098815] usbcore: registered ne� interface driver rtl8150
[ 10.104614] usbcore: registered ne� interface driver asi
[ 10.110107] usbcore: registered ne� interface driver cdc_ether
[ 10.116088] usbcore: registered ne� interface driver dm9601
[ 10.121795] usbcore: registered neJ�ѕə��� driver smsc95�x
+��r����ª] usbcore: registered ne� interface driver gl620a
[ 10.133361] usbcore: registered neJ�ѕə��� dri�er net1080
[ 10.139160] usbcore: registered ne� interface driver plusb
[ 10.144775] usbcore: registered new interface driver rndis_host
k��r���¢�] usbcore: registered new interface driver cdc_subset
[ 10.156860] usbcore: registered neJ�ѕə��� driver aurus
+��r������] usbcore: registered neJ�ѕə��� driver M_SCHIP usb-ethernet driver
[ 10.170623] ehci_hcd: USB 2.0 ‘Enhanced’ Hst Cntrller (EHCI) Driver
[ 10.177459] ehci-map ehci-map.0: _MAP-EHCI Hst Cntrller
[��r�š���] ehci-map ehci-map.0: ne� USB bus registered, assigned bus number 2
[ 10.191070] ehci-map ehci-map.0: irq 77, io mem 0�48064800
[ 10.211883] ehci-map ehci-map.0: USB 2.0 started, EHCI 1.00
+��r������] usb usb2: NeUSB device found, idVendr=1d6b, idPrduct=0002
[ 10.224639] usb usb2: New USB device strings: Mfr=3, Prduct=2, SerialNumber=1
[ 10.231933] usb usb2: Prduct: OMAP-EHCI Hst Cntrller
[ 10.237304] usb usb2: Manufacturer: Linu� 2.6.32 ehci_hcd
[ 10.242736] usb usb2: SerialNumber: ehci-map.0
[ 10.247955] hub 2-0:1.0: USB hub found
+��r���‚�] hub 2-0:1.0: 3 ports detected
+��r�’���] Initialiing USB Mass Strage driver…
[ 10.287384] usbcore: registered ne� interface driver usb-storage
[ 10.293457] USB Mass Strage support registered.
[ 10.298461] mice: PS?2 mouse device commn for all mice
[ 10.304107] input: gpio-ke~.
� /devices/platform?gpio-ke~������?in�ut0
[ 10.311920] input: twl4030_p�rbuttn as /devices/platfrm?i2c_map.1?i2c-1?1-0049/twl4030_p�rbuttn/input?input1
[ 10.322631] i2c /dev entries driver
[ 10.326690] Linu� video capture interface: v2.00
[ 10.331634] omap-immu omap-immu.0: isp: versin 1.1
[ 10.338317] vpfe_init
+��r����²] OMAP Watchdg Timer Rev 0�31: initial timeout 60 sec
+��r���ʲ�] cpuidle: using governr ladder
[ 10.352081] cpuidle: using governr menu
[ 10.462158] mmci-ma�-hs mmci-map-hs.1: err -16 configuring card detect
[ 10.469177] Registered led device: beagleboard::usr0
[ 10.474334] Registered led device: beagleboard::usr1
[ 10.480865] Registered led device: beagleboard::pmu_stat
[ 10.487945] usbcore: registered new interface driver usbhid
[ 10.493591] usbhid: USB HID core driver
[ 10.497619] Advanced Linu� Sund Architecture Driver Version 1.0.21.
[ 10.504516] usbcore: registered neJ�ѕə��� driver snd-usb-audio
[ 10.591430] No device for DAI omap-mcbsp-dai-0
+��r�ʪʢ�] No device for DAI omap-mcbsp-dai-1
+��r������] No device for DAI omap-mcbsp-dai-2
[ 10.604888] No device for DAI omap-mcbsp-dai-3
+��r��ʚ��] No device for DAI map-mcbsp-dai-4
[ 10.613861] OMAP3 Beagle SC init
[ 10.618011] asoc: twl4030 |-> omap-mcbsp-dai-0 map�ing ok
[ 10.629486] ALSA device list:
+��r������] #0: omap3beagle (twl4030)
[ 10.636474] oprfile: using arm?arm�7
[ 10.640380] TCP cubic registered
[ 10.643676] NET: Registered prtcol famil~��j
+��r��Šʚ] NET: Registered prtcol famil~��j
[ 10.652770] lib80211: commn rutines for IEEE802.s
[ 10.658508] ThumbEE CPU e�tensin sup�orted.
[ 10.662811] Po_� Management for TI OMAP3.
[ 10.668090] SmartRefle� driver initialied
[ 10.672363] omap3beaglelmb: Driver registratin complete
[ 10.686126] VFP sup�ort v0.3: implementr 41 architecture 3 part 30 variant c rev 3
[ 10.694366] registered taskstats versin 1
[ 10.699218] fbcvt: 640480@60: CVT Name - .307M3-R
[ 10.713012] Cnsole: s�itching t colur frame buffer device 80�30
+��r������] regulatr_init_complete: incomplete constraints, leaving VAUX3 on
+��r������] regulatr_init_complete: incomplete constraints, leaving VDAC n
[��r������] omap_vout omap_vout: prbed for an unknwn device
[ 10.749237] Waiting for rt device /dev/mmcblk0p2…
[ 10.899597] mmc0: host des not support reading read-onl~��itch. assuming �rite-enable.
[ 10.907745] mmc0: ne� high speed SDHC card at address e624
[ 10.913574] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 10.918304] mmcblk0: p1 p2
[ 12.738952] kjurnald starting. Cmmit interval 5 seconds
[ 12.746002] EXT3-fs (mmcblk0p2): using internal journal
[ 12.751281] EXT3-fs (mmcblk0p2): recover~�����ѕk
[��r��²��] EXT3-fs (mmcblk0p2): munted files�stem �ith �riteback data mode
[ 12.765838] VFS: Munted rt (e�t3 files�stem) n device 179:2.
[ 12.777343] devtmpfs: mounted
[ 12.780395] Freeing init memr~'���Z5
C�Please �ait: booting…g
Starting udev
[ 13.440917] udev: starting versin 151
Remounting rt file s~.WV��ɮH�Caching udev devnodes
Ppulating dev cache
+��r������] Bluetth: Core ver 2.15
[ 18.678527] NET: Registered prtcol famil~��j
+��r�š���] Bluetth: HCI device and connection manager initiali�ed
[ 18.689483] Bluetth: HCI socket la�er initiali�ed
+��r��ʪ��] Bluetth: L2CAP ver 2.14
[ 18.713287] Bluetth: L2CAP socket la�er initiali�ed
+��r������] Bluetth: HIDP (Human Interface Emulatin) ver 1.2
[ 18.843261] NET: Registered prtcol famil~��j
[ 18.875061] Bluetth: RFCOMM TTY la�er initialied
[ 18.880096] Bluetth: RFC_MM socket la�er initiali�ed
[ 18.885284] Bluetth: RFC_MM ver 1.11
ALSA: Restring mi�er settings…
Configuring netwrk interfaces… ifconfig: SI_CGIFFLAGS: No such device
ifr� such device: No such device
e
Z������: SI_CGIFFLAGS: N such device
usb0 N such device
dne.
Starting portmap daemn: portmap.
net.ipv4.conf.default.rp_filter } 1
net.ipv4.conf.all.rp_filter } 1
hwclck: can’t pen ‘/dev/misc/rtc’: No such file r directr~C�ɥ Feb 17 01:46:00 GMT 2012
INIT: Enteringj��ͅ�� bus: dbus./rtc’: No such file r directr~C
Starting Hardware abstraction la~Y.B���5
jW�ѥ�� Drpbear SSH server: drpbear.
Starting advanced power management daemn: N APM support in kernel
(failed.)
Starting Vi�ie-crn.
S
��(.W˝ Samba: smbdr�����
Starting s~.���?klgd: dne
Starting internet superserver: �inetd.
[ k ]rting Avahi mDNS?DNS-SD Daemon: avahi-daemon
Starting Netwrk connection manager daemn: NetwrkManager.
N SGX hardware, not starting PVR
���: started scheduler.
Starting GN_ME Displa� Manager gdm
������� j
__ | —'| ‘–.| .-’| | |
The Angstrm Distribution beagleboard tt~*j
Angstrm 2010.7-test-20110220 beagleboard tt~*j
beagleboard lgin: rootC�rot@beagleboard:~#
Also, I don’t know why I am getting such junk characters on the screen. Please help me remove them.
Looking forward to your positive response.
Cheers,
Jayneil.
