Hi, I always used beaglebone white before, and I bought a new BBB one week ago.
I followed steps on https://eewiki.net/display/linuxonarm/BeagleBone+Black to start with my BBB (so does Beaglebone white),
However, my computer cannot detect ttyUSB0 through USB socket, but LEDs on BBB can blink. It seems microSD works.
I followed the steps on eewiki except “usb gadget”, “HDMI”, “eMMC”, and “SGX” parts.
I also followed steps for beaglebone white on eewiki and that works. (Debian, v3.8, my Ubuntu can detect ttyUSB0 correctly, so I guess that is not problem of file system or kernel or my host PC.)
I don’t know what happened to my beaglebone black, I guess that the problem comes from inittab or uEnv.txt, but I have no idea how to deal with it. (my BBB is Rev.C).
If I eject my microSD form BBB, my host PC can detect ttyACM0 (that is a system on eMMC), but I have to use a recompiled kernel rather than Debian on eMMC.
Thanks.
Your getting tricked by a little software trickery. On the original
BeagleBone, there was an ftdi based usb-serial chip connected to the
usb slave port to give your pc a raw "/dev/ttyUSB0" device. On the
BeagleBone Black this was removed to save $'s..
However, there is a usb-serial gadget, so we get the kernel to create
a usb-serial device (/dev/ttyACM0) in the default image. It's done
here:
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/am335x_evm.sh#L76
That "usb gadget" section on my eewiki.net page would have enabled
that usb-serial gadget too..
Nice to meet you, Robert !
Could you teach me how to use your use-serial gadget ?(where to put it)
I am a rookie… and I read your tutorial on eewiki for usb gadget, it says “Provides http access to beaglebone black over usb.”
I thought I didn’t need http access, so I didn’t handle it before.
Thanks.
RobertCNelson於 2014年7月10日星期四UTC+8下午9時49分07秒寫道:
usb ethernet is probably the most used gadget, hence i only mention
that. It also set's up /dev/mmcblk0p1 to be a usb flash drive, along
with the usb-serial gadget driver.
to make serial work, you'll also have to add: [ttyGS0]
https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-SerialLogin
If you don't want the usb networking stuff you can disable it..
https://raw.githubusercontent.com/RobertCNelson/tools/master/scripts/beaglebone-black-g-ether-load.sh
Just download and run on your bbb
