my metal detector development for beaglebone black
hi guys i am wanting to build a new type of metal detector which in it self is quite complex task starting with little bits c/c++ code and tying to keep it simple i need to wirite 7 values of either on or off to 1 gpio but infact need to a total of 7 gpio’s all as one cycle so i have set patern of on or off values across the 7 gpios after that patern is executed is anthoner fixed pattern is done 7 times which the whole thing keeps repeating the pattern below shows the state of the switches s57-s64 the gpio’s need to be turn on in that order to turn the transistors on if some could hep i would be greatful
S57 S58 S59 S60 S61 S62 S63 S64
on off off on n/a on n/a off
on off off on n/a off n/a on
off on on off on n/a off n/a −
off on on off off n/a on n/a
off off on on on on off off
off off on on on off off on
off off on on off on on off +
but infact need to a total of 7 gpio's all as one cycle so i have set
the gpio's need to be turn on in that order to turn the transistors on if
*if* you can write these 8 values as a single byte then it's just a
lookup table with an index. That should get the entire 8 bits change
at one time. This can happen in some processors, and not in others. I
don't know this particular processor at all, so I can't say that this
is possible.
it's a possibility, but you need to look at the processor
documentation to see if it can be done. Again, I do *not* know this
processor at all, but it can be done in other processors depending on
how the I/O ports are mapped.
Your best bet is to look at the documentation on the GPIO pins and how
they can be changed.
Harvey
