NAND flash booting problem.
hi all,
i am working on B board,
i have done some changes in the kernel code to create one extra MTD
partition as shown below.
0x00000000-0x00080000 : "X-Loader"
0x00080000-0x00260000 : "U-Boot"
0x00260000-0x00280000 : "U-Boot Env"
0x00280000-0x00680000 : "Kernel"
0x00680000-0x01940000 : "File System"
0x01940000-0x10000000 : "EXTENDED PARTITION"
this image (uImage) is working fine if i boot from SD card.
but not working if i boot from NAND flash.
i got the following errors.
Starting
kernel ...
Uncompressing
Linux.............................................................
Linux version 2.6.28-rc9-omap1 (msrsas@ubuntu) (gcc version 4.2.1
(CodeSourcery2
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction
cache
Machine: OMAP3 DevKit8000
Board
Memory policy: ECC disabled, Data cache
writeback
OMAP3430 Unknown
revision
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size:
0x100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
65024
Kernel command line: console=ttyS2,115200n8 ubi.mtd=0 root=ubi0:rootfs
rootfstyD
Clocking rate (Crystal/DPLL/ARM core): 26.0/266/500
MHz
GPMC revision
5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96
interrupts
Total of 96 interrupts on 1 active
controller
OMAP34xx GPIO hardware version
2.5
PID hash table entries: 1024 (order: 10, 4096
bytes)
OMAP clockevent source: GPTIMER12 at 32768
Hz
Console: colour dummy device
80x30
Dentry cache hash table entries: 32768 (order: 5, 131072
bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
Memory: 128MB 128MB = 256MB
total
Memory: 255104KB available (4056K code, 360K data, 148K
init)
Calibrating delay loop... 470.56 BogoMIPS
(lpj=1839104)
Mount-cache hash table entries:
512
CPU: Testing write buffer coherency:
ok
net_namespace: 288
bytes
NET: Registered protocol family
16
Found NAND on
CS0
Registering NAND on
CS0
omap3evmdc: Driver registration
complete
OMAP DMA hardware revision
4.0
USB: No board-specific platform config
found
OMAP DSS rev
2.0
OMAP DISPC rev
3.0
OMAP VENC rev
2
OMAP DSI rev
1.0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600
kHz
twl4030: PIH (irq 7) chaining IRQs
368..375
twl4030: power (irq 373) chaining IRQs
376..383
twl4030: gpio (irq 368) chaining IRQs
384..401
i2c_omap i2c_omap.2: bus 2 rev3.12 at 400
kHz
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400
kHz
SCSI subsystem
initialized
twl4030_usb twl4030_usb: Initialized TWL4030 USB
module
usbcore: registered new interface driver
usbfs
hub
usbcore: registered new device driver
usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host),
debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ
92
2
IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
TCP established hash table entries: 8192 (order: 4, 65536
bytes)
TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
TCP: Hash tables configured (established 8192 bind
8192)
TCP reno
registered
1
NetWinder Floating Point Emulator V0.97 (double
precision)
VFS: Disk quotas
dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat,
Inc.
msgmni has been set to
498
alg: No test for stdrng
(krng)
io scheduler noop
registered
io scheduler anticipatory registered
(default)
io scheduler deadline
registered
io scheduler cfq
registered
Serial: 8250/16550 driver4 ports, IRQ sharing
enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
console [ttyS2]
enabled
brd: module
loaded
loop: module
loaded
PPP generic driver version
2.4.2
PPP Deflate Compression module
registered
PPP BSD Compression module
registered
PPP MPPE Compression module
registered
24
PPPoL2TP kernel driver,
V1.0
dm9000 Ethernet Driver,
V1.31
eth0: dm9000a at d08c4000,d08c8400 IRQ 185 MAC: 00:11:22:33:44:55
(chip)
Linux video capture interface:
v2.00
tvp514x 2-005d: Registered to v4l2 master
omap34xxcam!!
uvcvideo
USB Video Class driver
(v0.1.0)
i2c /dev entries
driver
Driver 'sd' needs updating - please use bus_type
methods
omap2-nand driver
initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB
1,8V 16-b)
cmdlinepart partition parsing not
available
Creating 6 MTD partitions on "omap2-
nand":
Loader"
Boot"
Env"
"Kernel"
System"
PARTITION"
UBI: attaching mtd0 to
ubi0
UBI: MTD device 0 is write-protected, attach in read-only
mode
UBI: physical eraseblock size: 131072 bytes (128
KiB)
UBI: logical eraseblock size: 129024
bytes
UBI: smallest flash I/O unit:
2048
UBI: sub-page size:
512
UBI: VID header offset: 512 (aligned
512)
UBI: data offset:
2048
UBI error: ubi_read_volume_table: the layout volume was not
found
UBI error: ubi_init: cannot attach
mtd0
UBI error: ubi_init: UBI error: cannot initialize UBI, error
-22
usbmon: debugfs is not
available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host
Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number
1
ehci-omap ehci-omap.0: irq 77, io mem
0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI
1.00
usb usb1: configuration #1 chosen from 1
choice
hub 1-0:1.0: USB hub
found
hub 1-0:1.0: 3 ports
detected
Initializing USB Mass Storage
driver...
usbcore: registered new interface driver usb-
storage
USB Mass Storage support
registered.
input: omap_twl4030keypad as /class/input/
input0
input: gpio-keys as /class/input/
input1
ads7846 spi2.0: touchscreen, irq
187
input: ADS784x Touchscreen as /class/input/
input2
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as
rtc0
twl4030_rtc twl4030_rtc: Power up reset
detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-
RTC.
Registered led device:
led1
led2
ledB
led3
usbhid
usbhid: v2.6:USB HID core
driver
Advanced Linux Sound Architecture Driver Version
1.0.18rc3.
ASoC version
0.13.2
OMAP3 omap3devkit8000 SoC
init
TWL4030 Audio Codec
init
asoc: twl4030 <-> omap-mcbsp-dai-(link_id) mapping
ok
ALSA device
list:
  #0: omap3devkit8000
(twl4030)
TCP cubic
registered
17
15
RPC: Registered udp transport
module.
RPC: Registered tcp transport
module.
Power Management for TI
OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
omapfb: using mode
4.3inch_LCD
Console: switching to colour frame buffer device
60x34
clock: clksel_round_rate_div: dpll4_m4_ck target_rate
48000000
clock: new_div = 9, new_rate =
48000000
tvp514x 2-005d: tvp5146m2 found at 0xba (OMAP I2C
adapter)
omap34xxcam omap34xxcam: video0 is now omap3/
tvp514x//
Display already
enabled
Display already
enabled
Buffer Size =
3686400
omap_vout: registered and initialized video device 1
[v4l2]
Buffer Size =
3686400
omap_vout: registered and initialized video device 2
[v4l2]
display-
updated
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00
UTC (94668)
UBIFS error (pid 1): ubifs_get_sb: cannot open "ubi0:rootfs", error
-19
VFS: Cannot open root device "ubi0:rootfs" or unknown-
block(0,0)
Please append a correct "root=" boot option; here are the available
partitions:
1f00 512 mtdblock0
(driver?)
1f01 1920 mtdblock1
(driver?)
1f02 128 mtdblock2
(driver?)
1f03 4096 mtdblock3
(driver?)
1f04 19200 mtdblock4
(driver?)
1f05 236288 mtdblock5
(driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-
block(0,0)
PLEASE SUGGEST ME HOW TO OVERCOME THIS PROBLEM.
THANKS AND REGARDS
N Reddy
