need help with build Angstrom image
I try to build the Angstrom image with the introduction from http://www.angstrom-distribution.org/building-%C3%A5ngstr%C3%B6m. I got this error when trying to do the bitbake command: ERROR: IO Error: file ‘conf/bitbake.conf’ not found
I don’t understand why it looks for this file cause we have the local.conf file?
Could you please tell me how to solve this?
Thank you
Thang Nguyen
Hello Thang,
We just had this discussion on the list about posting to the right mailing list.
can you please explain why you post to the beagle mailing list while
you are clearly following
the documentation on the http://www.angstrom-distribution.org/ website?
Can you also try to follow http://elinux.org/BeagleBoardAndOpenEmbeddedGit
and tel us if that goes better?
Thank you!
Becasue it is the documentation recommended by http://elinux.org/BeagleBoard#OpenEmbedded,
I expect.
I'm having the same problem.
kb
... it is definitely working better using the instructions n
http://elinux.org/BeagleBoardAndOpenEmbeddedGit !!
the documentation on thehttp://www.angstrom-distribution.org/website?
Because that's the one and only doc for building angstrom. It might be
a good idea to not second-guess lead developers on their projects.
