Need help with glib2 not found
Hi ,
I set up another environment to run oe now because the other company melted down .
I am getting this error and I think it is just misconfig. Do you know how to fix this problem?
I did run “git pull” to get the latest before running bitbake.
NOTE: make
make all-recursive
make[1]: Entering directory /home/anne/oe/tmp/work/armv7a-angstrom-linux-gnueabi/ortp-0.7.1-r1/ortp-0.7.1' Making all in src make[2]: Entering directory /home/anne/oe/tmp/work/armv7a-angstrom-linux-gnueabi/ortp-0.7.1-r1/ortp-0.7.1/sr$
Making all in .
make[3]: Entering directory `/home/anne/oe/tmp/work/armv7a-angstrom-linux-gnueabi/ortp-0.7.1-r1/ortp-0.7.1/sr$
/bin/sh …/arm-angstrom-linux-gnueabi-libtool --tag=CC --mode=compile arm-angstrom-linux-gnueabi-gcc -march$
arm-angstrom-linux-gnueabi-libtool: compile: arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mtune=cortex-a8 $
In file included from str_utils.c:20:
…/include/ortp/rtpport.h:146:18: error: glib.h: No such file or directory
…/include/ortp/rtpport.h:291: error: expected specifier-qualifier-list before ‘guint16’
…/include/ortp/rtpport.h:298: error: expected specifier-qualifier-list before ‘guint32’
In file included from str_utils.c:21:
…/include/ortp/rtp.h:48: error: expected specifier-qualifier-list before ‘guint16’
…/include/ortp/rtp.h:66: error: expected specifier-qualifier-list before ‘guint64’
In file included from str_utils.c:22:
…/include/ortp/str_utils.h:42: error: expected specifier-qualifier-list before ‘guint’
…/include/ortp/str_utils.h:49: error: expected specifier-qualifier-list before ‘gint’
…/include/ortp/str_utils.h:68: error: expected ‘)’ before ‘size’
…/include/ortp/str_utils.h:92: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘msgdsize’
…/include/ortp/str_utils.h:103: error: expected declaration specifiers or ‘…’ before ‘gboolean’
…/include/ortp/str_utils.h:104: error: expected declaration specifiers or ‘…’ before ‘gboolean’
str_utils.c: In function ‘qinit’:
str_utils.c:31: error: ‘queue_t’ has no member named ‘q_mcount’
str_utils.c: In function ‘allocb’:
str_utils.c:44: error: ‘gchar’ undeclared (first use in this function)
str_utils.c:44: error: (Each undeclared identifier is reported only once
str_utils.c:44: error: for each function it appears in.)
str_utils.c:44: error: ‘buf’ undeclared (first use in this function)
str_utils.c:46: warning: implicit declaration of function ‘g_malloc’
str_utils.c:46: warning: assignment makes pointer from integer without a cast
str_utils.c:48: warning: assignment makes pointer from integer without a cast
