NEON optimised cmath like library.
Hello
I've just began work on a NEON optimised cmath like library. You can
see what I've done so far here:
http://code.google.com/p/math-neon/
I don't have any hardware to test on so I've mainly been focusing on
branchless C implementations (except where the branch can be
precaclulated on the ARM). I want it to be more game targeted than
DSP, so I've made some large approximations to gain performance. All
of the currently implemented functions i've written from scratch using
Mathematica to generate minimax polynomials.
In C: sinf, cosf, tanf, atanf, powf, logf and expf.
In NEON asm: sinf, tanf and atanf.
I've been considering entering it into the contest i just found on the
wiki. Is this a good idea? Might be an easy way to get some
hardware....
I'm very new to this stuff, this is the first real assembly I've
written. So any tips or comments on bugs in code would be much
appreciated.
PS: I've also began work on a OGL to OGLESv2 translator. You can find
it here:
http://code.google.com/p/gl-wes-v2/
Haven't worked on it alot recently, but it does implement a useful
subset. For instance i dynamically generate fragment shaders for OGL2
compliant multitexturing combinors, fog, alpha test support.
lachlan wrote:
Hello
Google Code Archive - Long-term storage for Google Code Project Hosting.
Yes, please do so!
Best regards
Dirk
Yes, please do so!
Best regards
Dirk
Alrighty, i think i entered Math-NEON correctly. I was considering
entering both projects together, since there both relevant to the
Beagleboard, but i opted against it since i'm not sure how much more
work i want to put into my OGL translator (Display Lists come to
mind).
Cheers,
