We have some legacy software running on BB White and BB Black (PCB Rev B6) for a while. Recently we have to build some more and using the Rev C BBB, the network fails to start. We are booting Debian from the same SD card, version 3.8.13-bone67.
Can anyone tell me why the more recent hardware stops the network working? How can I get it going again?
Looking at the revision history on the schematics, the only difference from Rev B to Rev C is the larger eMMC.
James
ifconfig gives the following output:
eth0 Link encap:Ethernet HWaddr 38:d2:69:57:93:ed
inet6 addr: fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed/64 Scope:Global
inet6 addr: fe80::3ad2:69ff:fe57:93ed/64 Scope:Link
RX packets:87010 errors:0 dropped:7 overruns:0 frame:0
TX packets:79 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7151565 (6.8 MiB) TX bytes:16941 (16.5 KiB)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr 92:7f:c3:3b:c8:09
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
UP BROADCAST MULTICAST MTU:1500 Metric:1
The following is part of the output of journalctl. It seems to show attempts to connect to the network?
Oct 09 01:28:04 beaglebone systemd[1]: Starting Multi-User System.
Oct 09 01:28:04 beaglebone systemd[1]: Reached target Multi-User System.
Oct 09 01:28:04 beaglebone systemd[1]: Starting Graphical Interface.
Oct 09 01:28:04 beaglebone systemd[1]: Reached target Graphical Interface.
Oct 09 01:28:04 beaglebone systemd[1]: Starting Update UTMP about System Runlevel Changes…
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface usb0.IPv4 with address 192.168.7.2.
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: New relevant interface usb0.IPv4 for mDNS.
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: Registering new address record for 192.168.7.2 on usb0.IPv4.
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: Withdrawing address record for 192.168.7.2 on usb0.
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface usb0.IPv4 with address 192.168.7.2.
Oct 09 01:28:05 beaglebone avahi-daemon[1206]: Interface usb0.IPv4 no longer relevant for mDNS.
Oct 09 01:28:05 beaglebone udhcpd[1518]: udhcpd (v1.20.2) started
Oct 09 01:28:05 beaglebone kernel: IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
Oct 09 01:28:05 beaglebone systemd[1]: Started Update UTMP about System Runlevel Changes.
Oct 09 01:28:05 beaglebone systemd[1]: Startup finished in 8.601s (kernel) + 15.137s (userspace) = 23.738s.
Oct 09 01:28:06 beaglebone dhclient[1540]: isc-dhclient-4.2.2
Oct 09 01:28:06 beaglebone dhclient[1541]: isc-dhclient-4.2.2
Oct 09 01:28:12 beaglebone login[1226]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
Oct 09 01:28:12 beaglebone systemd-journal[210]: Forwarding to syslog missed 62 messages.
Oct 09 01:28:12 beaglebone login[1546]: ROOT LOGIN on ‘/dev/ttyO0’
Oct 09 01:28:13 beaglebone kernel: net eth0: initializing cpsw version 1.12 (0)
Oct 09 01:28:13 beaglebone kernel: net eth0: phy found : id is : 0x7c0f1
Oct 09 01:28:13 beaglebone kernel: libphy: PHY 4a101000.mdio:01 not found
Oct 09 01:28:13 beaglebone kernel: net eth0: phy 4a101000.mdio:01 not found on slave 1
Oct 09 01:28:13 beaglebone kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 09 01:28:16 beaglebone kernel: libphy: 4a101000.mdio:00 - Link is Up - 100/Full
Oct 09 01:28:16 beaglebone kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 09 01:28:17 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:28:17 beaglebone avahi-daemon[1206]: New relevant interface eth0.IPv6 for mDNS.
Oct 09 01:28:17 beaglebone avahi-daemon[1206]: Registering new address record for fe80::3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:28:19 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:28:19 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed.
Oct 09 01:28:19 beaglebone avahi-daemon[1206]: Registering new address record for fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:28:19 beaglebone avahi-daemon[1206]: Withdrawing address record for fe80::3ad2:69ff:fe57:93ed on eth0.
Oct 09 01:28:20 beaglebone dhclient[1576]: Internet Systems Consortium DHCP Client 4.2.2
Oct 09 01:28:20 beaglebone dhclient[1576]: Copyright 2004-2011 Internet Systems Consortium.
Oct 09 01:28:20 beaglebone dhclient[1576]: All rights reserved.
Oct 09 01:28:20 beaglebone dhclient[1576]: For info, please visit https://www.isc.org/software/dhcp/
Oct 09 01:28:20 beaglebone dhclient[1576]: Listening on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:20 beaglebone dhclient[1576]: Sending on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:20 beaglebone dhclient[1576]: Sending on Socket/fallback
Oct 09 01:28:20 beaglebone dhclient[1576]: DHCPRELEASE on eth0 to 192.168.1.1 port 67
Oct 09 01:28:20 beaglebone dhclient[1576]: send_packet: Network is unreachable
Oct 09 01:28:20 beaglebone dhclient[1576]: send_packet: please consult README file regarding broadcast address.
Oct 09 01:28:20 beaglebone avahi-daemon[1206]: Interface eth0.IPv6 no longer relevant for mDNS.
Oct 09 01:28:20 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface eth0.IPv6 with address fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed.
Oct 09 01:28:20 beaglebone avahi-daemon[1206]: Withdrawing address record for fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed on eth0.
Oct 09 01:28:20 beaglebone kernel: net eth0: initializing cpsw version 1.12 (0)
Oct 09 01:28:20 beaglebone kernel: net eth0: phy found : id is : 0x7c0f1
Oct 09 01:28:20 beaglebone kernel: libphy: PHY 4a101000.mdio:01 not found
Oct 09 01:28:20 beaglebone kernel: net eth0: phy 4a101000.mdio:01 not found on slave 1
Oct 09 01:28:20 beaglebone kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 09 01:28:21 beaglebone dhclient[1604]: Internet Systems Consortium DHCP Client 4.2.2
Oct 09 01:28:21 beaglebone dhclient[1604]: Copyright 2004-2011 Internet Systems Consortium.
Oct 09 01:28:21 beaglebone dhclient[1604]: All rights reserved.
Oct 09 01:28:21 beaglebone dhclient[1604]: For info, please visit https://www.isc.org/software/dhcp/
Oct 09 01:28:21 beaglebone dhclient[1604]: Listening on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:21 beaglebone dhclient[1604]: Sending on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:21 beaglebone dhclient[1604]: Sending on Socket/fallback
Oct 09 01:28:21 beaglebone dhclient[1604]: DHCPRELEASE on eth0 to 192.168.1.1 port 67
Oct 09 01:28:21 beaglebone dhclient[1604]: send_packet: Network is unreachable
Oct 09 01:28:21 beaglebone dhclient[1604]: send_packet: please consult README file regarding broadcast address.
Oct 09 01:28:21 beaglebone kernel: net eth0: initializing cpsw version 1.12 (0)
Oct 09 01:28:21 beaglebone kernel: net eth0: phy found : id is : 0x7c0f1
Oct 09 01:28:21 beaglebone kernel: libphy: PHY 4a101000.mdio:01 not found
Oct 09 01:28:21 beaglebone kernel: net eth0: phy 4a101000.mdio:01 not found on slave 1
Oct 09 01:28:21 beaglebone kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 09 01:28:23 beaglebone kernel: libphy: 4a101000.mdio:00 - Link is Up - 100/Full
Oct 09 01:28:23 beaglebone kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 09 01:28:23 beaglebone dhclient[1613]: Internet Systems Consortium DHCP Client 4.2.2
Oct 09 01:28:23 beaglebone dhclient[1613]: Copyright 2004-2011 Internet Systems Consortium.
Oct 09 01:28:23 beaglebone dhclient[1613]: All rights reserved.
Oct 09 01:28:23 beaglebone dhclient[1613]: For info, please visit https://www.isc.org/software/dhcp/
Oct 09 01:28:23 beaglebone dhclient[1613]: Listening on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:23 beaglebone dhclient[1613]: Sending on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:28:23 beaglebone dhclient[1613]: Sending on Socket/fallback
Oct 09 01:28:23 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Oct 09 01:28:24 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:28:24 beaglebone avahi-daemon[1206]: New relevant interface eth0.IPv6 for mDNS.
Oct 09 01:28:24 beaglebone avahi-daemon[1206]: Registering new address record for fe80::3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:28:25 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:28:25 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed.
Oct 09 01:28:25 beaglebone avahi-daemon[1206]: Registering new address record for fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:28:25 beaglebone avahi-daemon[1206]: Withdrawing address record for fe80::3ad2:69ff:fe57:93ed on eth0.
Oct 09 01:28:27 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
Oct 09 01:28:32 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 9
Oct 09 01:28:41 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
Oct 09 01:28:53 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 11
Oct 09 01:29:04 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14
Oct 09 01:29:18 beaglebone dhclient[1613]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
Oct 09 01:29:24 beaglebone dhclient[1613]: No DHCPOFFERS received.
Oct 09 01:29:24 beaglebone dhclient[1613]: No working leases in persistent database - sleeping.
Oct 09 01:29:27 beaglebone dhclient[1645]: Internet Systems Consortium DHCP Client 4.2.2
Oct 09 01:29:27 beaglebone dhclient[1645]: Copyright 2004-2011 Internet Systems Consortium.
Oct 09 01:29:27 beaglebone dhclient[1645]: All rights reserved.
Oct 09 01:29:27 beaglebone dhclient[1645]: For info, please visit https://www.isc.org/software/dhcp/
Oct 09 01:29:27 beaglebone dhclient[1645]: Listening on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:29:27 beaglebone dhclient[1645]: Sending on LPF/eth0/38:d2:69:57:93:ed
Oct 09 01:29:27 beaglebone dhclient[1645]: Sending on Socket/fallback
Oct 09 01:29:28 beaglebone dhclient[1645]: DHCPRELEASE on eth0 to 192.168.1.1 port 67
Oct 09 01:29:28 beaglebone dhclient[1645]: send_packet: Network is unreachable
Oct 09 01:29:28 beaglebone dhclient[1645]: send_packet: please consult README file regarding broadcast address.
Oct 09 01:29:28 beaglebone avahi-daemon[1206]: Interface eth0.IPv6 no longer relevant for mDNS.
Oct 09 01:29:28 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface eth0.IPv6 with address fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed.
Oct 09 01:29:28 beaglebone avahi-daemon[1206]: Withdrawing address record for fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed on eth0.
Oct 09 01:29:28 beaglebone kernel: net eth0: initializing cpsw version 1.12 (0)
Oct 09 01:29:28 beaglebone kernel: net eth0: phy found : id is : 0x7c0f1
Oct 09 01:29:28 beaglebone kernel: libphy: PHY 4a101000.mdio:01 not found
Oct 09 01:29:28 beaglebone kernel: net eth0: phy 4a101000.mdio:01 not found on slave 1
Oct 09 01:29:28 beaglebone kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Oct 09 01:29:30 beaglebone kernel: libphy: 4a101000.mdio:00 - Link is Up - 100/Full
Oct 09 01:29:30 beaglebone kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Oct 09 01:29:31 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:29:31 beaglebone avahi-daemon[1206]: New relevant interface eth0.IPv6 for mDNS.
Oct 09 01:29:31 beaglebone avahi-daemon[1206]: Registering new address record for fe80::3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:29:33 beaglebone avahi-daemon[1206]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::3ad2:69ff:fe57:93ed.
Oct 09 01:29:33 beaglebone avahi-daemon[1206]: Joining mDNS multicast group on interface eth0.IPv6 with address fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed.
Oct 09 01:29:33 beaglebone avahi-daemon[1206]: Registering new address record for fd78:6a89:d8ad:3100:3ad2:69ff:fe57:93ed on eth0..
Oct 09 01:29:33 beaglebone avahi-daemon[1206]: Withdrawing address record for fe80::3ad2:69ff:fe57:93ed on eth0.
Oct 09 01:29:35 beaglebone sh[1213]: hwclock: Cannot access the Hardware Clock via any known method.
Oct 09 01:29:35 beaglebone sh[1213]: hwclock: Use the --debug option to see the details of our search for an access method.
Oct 09 01:42:41 beaglebone systemd[1]: Starting Cleanup of Temporary Directories…
Oct 09 01:42:41 beaglebone systemd[1]: Started Cleanup of Temporary Directories.
root@beaglebone:~# cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
#auto eth0
#iface eth0 inet dhcp
Example to keep MAC address between reboots
#hwaddress ether DE:AD:BE:EF:CA:FE
The secondary network interface
#auto eth1
#iface eth1 inet dhcp
WiFi Example
#auto wlan0
#iface wlan0 inet dhcp
wpa-ssid “essid”
wpa-psk “password”
Ethernet/RNDIS gadget (g_ether)
… or on host side, usbnet and random hwaddr
Note on some boards, usb0 is automaticly setup with an init script
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
