Every time my BB-xM reboots it gives a different mac address so my
DHCP server gives it a new ip address. It is against company policy
where I work to give anything on the network a static ip address. So
every time I reboot I need to connect a monitor and keyboard to the BB
to find out what it's IP address so I can SSH into it to start my
work...inconvenient.
I thought I would give it a network name like BBxM01 so I could find
it on the network. But the BB-xM does not seem to show up on our
network with a name.
What is the best workaround for this? Is there a way to give it a
name on the network that will show up? Or an easy way to make it use
the same MAC address?
to find out what it’s IP address so I can SSH into it to start my
work…inconvenient.
Angstrom has avahi enabled by default, so if your routers aren't blocking mdns (they do over here), you can do:
ssh root@beagleboard.local
If you want to use a different name, change /etc/hostname to e.g. BBxM01 and you can reach it at BBxM01.local
Since you mentioned avahi with Angstrom here maybe you can provide
some suggestions regarding the problem I am observing since quite some
time but did not get to investigate it deeper yet.
In my setup I have BB with WLan with Angstrom running avahi/mdns
daemon and Debian running on my notebook. All in local network
connected over the access point. Name resolution works (i.e. I can do
ssh or ping for beagleboard.local). However it works only for about
1-3 minute after the start of avahi daemon. After that, the
beagleboard.local name could not be resolved. Restarting avahi daemon
on BB helps but also only for about 1 minute.
So I am wondering if you have any experience using avahi over the
longer time and if yes, are there any additional configuration might
be necessary either on BB/Angstrom side or on other hosts side to
prevent the "forgetting" of the name?
The pandaboard I booted >100 days ago still responds to pandaboard.local and I didn't change anything. I'm not sure what would case mdns to seize after a few minutes
Well, then the problem is probably somewhere else in my setup.
Will need to investigate it deeper.
I am using the LAN9514 chip on the beagleboard-xm so the ip address
always show up as a 'usb0' interface so I modified the interfaces file
to have the following.
The Embedded Linux class I’m in has two workarounds that I know of:
-The kernel patch linked to above will allow you to specify a MAC address to the kernel as a command-line argument. You’ll need to configure u-boot or change your boot script to give a MAC address this way. When I was not using a prebuilt image, this was how I did it, but when I switched to a prebuilt image, I stopped compiling my own kernel/u-boot.
-Use a USB->Network adapter. Trendnet’s TU2-ET100 has worked in at least two cases so far, but there are other adapters that work.
I have tried the /etc/network/interfaces approach without success. I don’t think anyone here has attempted the udev rules approach.
Hopefully, someone else from the class will correct me if I’m misinformed.
David Bliss
Computer Science, Rose-Hulman, 2012
1-616-284-1273
