If you read further down the web page it tells you how to manually download the packages following the links given to get them and then use opkg to install them.
I tried to install it like the instruction on the webpage because i get the package not found error. but every server which hosts these packages is down. any ideas where to get the right sutff?
pederm i have installed oracle java as you have suggested but i am now trying to launch processing.js to run some code but can’t get it to work, any ideas?
Hi Paulo
No i want to use processing to run a gui i have designed in processing, this will eventually control and arduino, i cant even get the processing IDE to load.
I followed the instructions online to install open jdk but as the links no longer worked someone else suggested using oracle instead, i have managed to get the processing window open once but now it won’t open at all.
Have you managed to get the processing IDE working on your BBB?
or do you have any sugesstions on how i can get it up and running?
Josh
Hi Paulo
I followed the instructions online to install open jdk but as the links no longer worked someone else suggested using oracle instead, i have managed to get the processing window open once but now it won't open at all.
No, my only suggestion is to build Processing from the source, after having installed openjdk….
