New angstrom demo image available
Jason asked me to create an new demo image for the people that haven't discovered narcissus yet, so here it is.
You can download it from these two sites:
Europe: http://www.angstrom-distribution.org/demo/beagleboard/Angstrom-Beagleboard-demo-image-glibc-ipk-2011.1-beagleboard.rootfs.tar.bz2
US West Coast: http://narcissus.angstrom-distribution.org/static/beagleboard/Angstrom-Beagleboard-demo-image-glibc-ipk-2011.1-beagleboard.rootfs.tar.bz2
Instructions on how to untar it can be found at:
If you want to recreate it using narcissus:
1) go to http://narcissus.angstrom-distribution.org/
2) select 'beagleboard' as machine
3) select 'X11' as user environment
4) select GNOME
5) select screen, powertop, mplayer, midori, TI texture streaming demo for X11 and Texas Instruments Gstreamer plugins
6) click 'Build me!'
If you want to recreate it using OE:
1) following instructions at http://www.angstrom-distribution.org/building-angstrom
2) MACHINE=beagleboard ./oebb.sh bitbake angstrom-gnome-image
It's going to a bit tight with RAM on revision B boards, but it works beautifully on revision C and xM.
regards,
Koen
I looked at this new version. I like it, /etc/fstab is very
interresting, but my kernel is 2.6.32, I didn't found the new 2.6.37.
Is there a way to get lighttpd with ssl ?
Thanks for Angstrom.
Hello Koen,
I'm trying to 'MACHINE=beagleboard ./oebb.sh bitbake angstrom-gnome-
image' for the first time from a Ubuntu 10.04 machine. I think I have
all my native packages required but am seeing the following error
(bison package related?). Any ideas on my configuration problems?
dell-xps@dell-xps-laptop:/media/Shared_FS/Ubuntu/projects/beagleboard/
angstrom/clone/angstrom-setup-scripts$ MACHINE=beagleboard ./oebb.sh
Updating bitbake
Executing: cd /media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/
clone/angstrom-setup-scripts/sources/bitbake && git pull --rebase
Current branch 1.10 is up to date.
Updating OpenEmbedded
Executing: git pull --rebase
Current branch org.openembedded.dev is up to date.
Using ~/.oe/environment to setup needed variables. It is recommended
to do '. ~/.oe/environment' and run 'bitbake something' without
using ./oebb.sh as wrapper
Executing: MACHINE=beagleboard bitbake angstrom-gnome-image
NOTE: Handling BitBake files: \ (7065/7065) [100 %]
Parsing of 7065 .bb files complete (6630 cached, 435 parsed). 7373
targets, 306 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION = "1.10.2"
METADATA_BRANCH = "org.openembedded.dev"
METADATA_REVISION = "0af4d2e"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "beagleboard"
DISTRO = "angstrom"
DISTRO_VERSION = "2010.7-test-20110114"
TARGET_FPU = "hard"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 411 of 10949 (ID: 3896, virtual:native:/media/
Shared_FS/Ubuntu/projects/beagleboard/angstrom/clone/angstrom-setup-
scripts/sources/openembedded/recipes/bison/bison_2.4.3.bb,
do_configure)
NOTE: package bison-native-2.4.3-r8.0: task do_configure: Started
NOTE: Running task 1002 of 10949 (ID: 665, virtual:native:/media/
scripts/sources/openembedded/recipes/util-linux-ng/util-linux-
ng_2.17.bb, do_configure)
NOTE: package util-linux-ng-native-2.17-r35: task do_configure:
Started
ERROR: TaskFailed event exception, aborting
ERROR: Build of virtual:native:/media/Shared_FS/Ubuntu/projects/
beagleboard/angstrom/clone/angstrom-setup-scripts/sources/openembedded/
recipes/bison/bison_2.4.3.bb do_configure failed
ERROR: Task 3896 (virtual:native:/media/Shared_FS/Ubuntu/projects/
recipes/bison/bison_2.4.3.bb, do_configure) failed with exit code 1
ERROR: Function do_configure failed
NOTE: Task failed: ('function do_configure failed', '/media/Shared_FS/
Ubuntu/projects/beagleboard/angstrom/clone/angstrom-setup-scripts/
build/tmp-angstrom_2008_1/work/i686-linux/bison-native-2.4.3-r8.0/temp/
log.do_configure.19618')
ERROR: Logfile of failure stored in: /media/Shared_FS/Ubuntu/projects/
beagleboard/angstrom/clone/angstrom-setup-scripts/build/tmp-
Log data follows:
automake (GNU automake) 1.11.1
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/
gpl-2.0.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by Tom Tromey <tromey@redhat.com>
       and Alexandre Duret-Lutz <adl@gnu.org>.
AUTOV is 1.11
NOTE: Executing autoreconf --verbose --install --force --
exclude=autopoint -I /media/Shared_FS/Ubuntu/projects/beagleboard/
angstrom/clone/angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/
i686-linux/bison-native-2.4.3-r8.0/bison-2.4.3/data/ -I /media/
scripts/build/tmp-angstrom_2008_1/work/i686-linux/bison-native-2.4.3-
r8.0/bison-2.4.3/m4/ -I /media/Shared_FS/Ubuntu/projects/beagleboard/
i686-linux/bison-native-2.4.3-r8.0/bison-2.4.3/tests/ -I/media/
scripts/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/share/
aclocal-1.11 -I /media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/
clone/angstrom-setup-scripts/build/tmp-angstrom_2008_1/sysroots/i686-
linux/usr/share/aclocal
autoreconf: Entering directory `.'
autoreconf: running: aclocal -I /media/Shared_FS/Ubuntu/projects/
angstrom_2008_1/work/i686-linux/bison-native-2.4.3-r8.0/bison-2.4.3/
data/ -I /media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/clone/
angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/i686-linux/bison-
native-2.4.3-r8.0/bison-2.4.3/m4/ -I /media/Shared_FS/Ubuntu/projects/
tests/ -I /media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/clone/
angstrom-setup-scripts/build/tmp-angstrom_2008_1/sysroots/i686-linux/
usr/share/aclocal-1.11 -I /media/Shared_FS/Ubuntu/projects/beagleboard/
sysroots/i686-linux/usr/share/aclocal -I /media/Shared_FS/Ubuntu/
projects/beagleboard/angstrom/clone/angstrom-setup-scripts/build/tmp-
sysroots/i686-linux/usr/share/aclocal --force -I m4
/media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/clone/angstrom-
native-2.4.3-r8.0/bison-2.4.3/m4/glib.m4:8: warning: underquoted
definition of AM_PATH_GLIB
native-2.4.3-r8.0/bison-2.4.3/m4/glib.m4:8: run info
'(automake)Extending aclocal'
native-2.4.3-r8.0/bison-2.4.3/m4/glib.m4:8: or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
autoreconf: configure.ac: tracing
configure.ac:128: warning: AC_RUN_IFELSE called without default to
allow cross compiling
../../lib/autoconf/general.m4:2716: AC_RUN_IFELSE is expanded
from...
../../lib/m4sugar/m4sh.m4:598: AS_IF is expanded from...
../../lib/autoconf/general.m4:1999: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2020: AC_CACHE_CHECK is expanded
from...
aclocal.m4:8870: gl_POSIX_SPAWN_WORKS is expanded from...
aclocal.m4:8799: gl_POSIX_SPAWN_BODY is expanded from...
aclocal.m4:8794: gl_POSIX_SPAWN is expanded from...
aclocal.m4:3234: gl_INIT is expanded from...
configure.ac:128: the top level
autoreconf: configure.ac: not using Libtool
autoreconf: running: /media/Shared_FS/Ubuntu/projects/beagleboard/
sysroots/i686-linux/usr/bin/autoconf --include=/media/Shared_FS/Ubuntu/
data/ --include=/media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/
clone/angstrom-setup-scripts/build/tmp-angstrom_2008_1/work/i686-linux/
bison-native-2.4.3-r8.0/bison-2.4.3/m4/ --include=/media/Shared_FS/
bison-2.4.3/tests/ --include=/media/Shared_FS/Ubuntu/projects/
angstrom_2008_1/sysroots/i686-linux/usr/share/aclocal-1.11 --include=/
setup-scripts/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/share/
aclocal --force --warnings=cross
from...
from...
sysroots/i686-linux/usr/bin/autoheader --include=/media/Shared_FS/
bison-2.4.3/data/ --include=/media/Shared_FS/Ubuntu/projects/
m4/ --include=/media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/
bison-native-2.4.3-r8.0/bison-2.4.3/tests/ --include=/media/Shared_FS/
build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/share/aclocal-1.11 --
include=/media/Shared_FS/Ubuntu/projects/beagleboard/angstrom/clone/
usr/share/aclocal --force --warnings=cross
autoreconf: failed to run /media/Shared_FS/Ubuntu/projects/
angstrom_2008_1/sysroots/i686-linux/usr/bin/autoheader: No such file
or directory
FATAL: autoreconf execution failed.
NOTE: package bison-native-2.4.3-r8.0: task do_configure: Failed
Waiting for 1 active tasks to finish:
1: util-linux-ng-native-2.17-r35 do_configure (pid 19658)
recipes/util-linux-ng/util-linux-ng_2.17.bb do_configure failed
ERROR: Task 665 (virtual:native:/media/Shared_FS/Ubuntu/projects/
recipes/util-linux-ng/util-linux-ng_2.17.bb, do_configure) failed with
exit code 1
ERROR: 'virtual:native:/media/Shared_FS/Ubuntu/projects/beagleboard/
angstrom/clone/angstrom-setup-scripts/sources/openembedded/recipes/
bison/bison_2.4.3.bb' failed
util-linux-ng/util-linux-ng_2.17.bb' failed
build/tmp-angstrom_2008_1/work/i686-linux/util-linux-ng-native-2.17-
r35/temp/log.do_configure.19658')
angstrom_2008_1/work/i686-linux/util-linux-ng-native-2.17-r35/temp/
Log data follows:
gpl-2.0.html>
AUTOV is 1.11
i686-linux/util-linux-ng-native-2.17-r35/util-linux-ng-2.17/m4/ -I/
angstrom_2008_1/work/i686-linux/util-linux-ng-native-2.17-r35/util-
linux-ng-2.17/m4/ -I /media/Shared_FS/Ubuntu/projects/beagleboard/
sysroots/i686-linux/usr/share/aclocal-1.11 -I /media/Shared_FS/Ubuntu/
angstrom_2008_1/sysroots/i686-linux/usr/share/aclocal -I /media/
scripts/build/tmp-angstrom_2008_1/work/i686-linux/util-linux-ng-
native-2.17-r35/util-linux-ng-2.17/m4/ -I /media/Shared_FS/Ubuntu/
angstrom_2008_1/sysroots/i686-linux/usr/share/aclocal-1.11 -I /media/
setup-scripts/build/tmp-angstrom_2008_1/work/i686-linux/util-linux-ng-
native-2.17-r35/util-linux-ng-2.17/m4/gettext.m4:430: warning: macro
`AM_LC_MESSAGES' not found in library
configure.ac:243: warning: AC_RUN_IFELSE called without default to
from...
../../lib/autoconf/general.m4:2697: _AC_RUN_IFELSE is expanded
from...
from...
aclocal.m4:11116: AX_CHECK_TLS is expanded from...
configure.ac:243: the top level
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `config'.
libtoolize: copying file `config/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
linux-ng-2.17/m4/ --include=/media/Shared_FS/Ubuntu/projects/
from...
from...
from...
r35/util-linux-ng-2.17/m4/ --include=/media/Shared_FS/Ubuntu/projects/
or directory
NOTE: package util-linux-ng-native-2.17-r35: task do_configure: Failed
exit code 1
Thanks Koen! I, for one, really appreciate this because I was unable
to get Nacissus to work... I'm sure it's something retarded I'm doing
wrong or possibly a busy time of the day that I'm trying to use it. It
never gets past one green check mark (even after 2+ hours).. anyway,
cheers for the demo image. I'm going to try it out soon.
-Jim
Hi Koen
  Tried out the new demo image and noticed the resolution is at
640x480, where the old demo image was 1280x720. Tried the "screen
gui" but that would not give me any choice for other screen settings.
Then I went looking for the screen config files in X11 but could not
find the one which would change the screen resolution. Should the
Angstrom setup be auto detecting the monitor? Looked in the Angstrom
manual but that did not help.
  Any hints would be appreciated.
   Carl
resolution is set using a boot.scr in the fat partition, you can do 'opkg update ; opkg install angstrom-uboot-scripts' to get a few example scripts.
regards,
Koen
As far as I know you have to do it at boot time.
mkimage is the command to use. It will generate a new boot file with
the prefered resolution.
That's why it is named a demo file, just a taster on what could be.
There are other things like filesharing you have to manual.
You have to look up the references to it.
Hello!
The latest demo does not have 3D demo applications. Can I install them and how? Please advise
Max
2011/1/18 Rico & Gaby Naef <familynaef@bluewin.ch>
Yes, with opkg
Can I just say this new image is just great. Everything is really
responsive and fast, especially Midori.
Thanks to Koen and all the rest of the team contributing.
Dear Koen,
can you specify the exact command to install 3D demo? I tried “opkh install libgles*” but new application do not appear.
P.S. Midori: works very unstable, often crashes almost immediately. Installed Firefox and everything is fine now.
2011/1/31 lchile <beaufortscale@gmail.com>
