New beaglebone image for testing
Could people experiencing the eth0 problem give http://dominion.thruhere.net/koen/angstrom/beaglebone/Angstrom-Cloud9-IDE-eglibc-ipk-v2011.12-core-beaglebone-2011.12.12.img.gz a try?
I tracked the bug down to permission problems, but the problem is intermittent so I'd like a few more data points.
No new packages were added, this is purely updates and bugfixes, a future update will hopefully include a fully functioning JDK and a graphical interface for people with DVI/LCD/etc capes.
regards,
Koen
And one with another connman fix:
http://dominion.thruhere.net/koen/angstrom/beaglebone/Angstrom-Cloud9-IDE-eglibc-ipk-v2011.12-core-beaglebone-2011.12.13.img.gz
Sorry for the noob question. Is this an image of the whole SD card or
just the root partition? I assume that I can just copy it with dd.
Here is the easy way...
http://www.angstrom-distribution.org/demo/beaglebone/
Thank you - eth0 is now coming up automatically.
Bingo! Ethernet is working using the 2011.12.13 version.
Mark
Thanks for the build Koen
I tried the 12.13 image, but the eth is still not up. My board probably has hardware problem. It says:
[ 1.955254] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.912132]
[ 3.912143] CPSW phy found : id is : 0x7c0f1
[ 3.919025] PHY 0:01 not found
[ 3.938896] ADDRCONF(NETDEV_UP): eth0: link is not ready
Not sure what to do.
My “rtl8187” USB WIFI is working with this image though.
Thanks again
-Thanh
— On Mon, 12/12/11, Koen Kooi koen@dominion.thruhere.net wrote:
> From: Koen Kooi koen@dominion.thruhere.net
> Subject: [beagleboard] Re: New beaglebone image for testing
> To: “beagleboard@googlegroups.com Board” beagleboard@googlegroups.com
> Date: Monday, December 12, 2011, 9:20 PM
> Op 12 dec. 2011, om 14:38 heeft Koen Kooi het volgende geschreven:
> > Hi,
> > I tracked the bug down to permission problems, but the problem is intermittent so I’d like a few more data points.
> > regards,
> > Koen
try changing the ethernet cable, the bone is quite picky
Koen,
The 12.13 image fixed my eth0 problem as well. Thanks!
Dan.
Hi All
I am looking at using a beagle board for a project I am working on.
Can the beagle board run ubuntu 10.04, play mpeg4 video.
Joseph
Yes, see http://www.elinux.org/BeagleBoard#Ubuntu. I really don't know how well mpeg4 video will play though.
Mark
