Hi
I made a couple of blog posts at
http://beagleboard-pwm.blogspot.com/
Currently building Angstrom with scripts from
http://gitorious.org/angstrom/angstrom-setup-scripts .
I am new to using version control systems, what I currently understand
about the git workflow is as follows
i. Git will create a local branch of Angstrom using the scripts from
the above page.
ii. I will then build Angstrom using the bitbake recipes and finally
load this up into a bootable SD card.
iii. I will run this new build on the Beagleboard and make whatever
changes i want to make and code some stuff.
iv. These changes I will then bring back to my local branch and I will
generate a patch and push it upstream for RFC.
As you can see my understanding of this workflow is very limited,
given that I have not contributed to an open source project
previously.
It would be great if you guys could comment where my understanding of
the workflow is incorrect and what I am missing in general....
Regards
Varun
