Newbie - Help Required.
I have been trying to test my new beagle board as per the newbies getting started guide here
http://elinux.org/BeagleBoardBeginners
and on my interaction through serial port using minicom i get an error message as follows
warning bad crc or NAND, using default environment
NAND read: device 0 offset 0x2880000, size 0x400000
4194384 bytes read: ok
Wrong Image Format for bootm command
ERROR: can’t get kernel Image!
Here is a screenshot : http://www.4shared.com/file/108768576/769e6da/error_shot.html
I would appreciate all help. Is there a problem with the board or is it the image file? if its the image file how do i reload it? ir should i ignore it and get angstorm on an sd card and get this runing?
This is normal. The board is set to boot the Kernel from files on the SD card. It appears that either you have no SD card plugged in or it is not correctly formatted and the required files loaded onto the card.
Check here for more informtion:
http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
